[Mapserver-users] Can't seem to get the projection correct
Martin, Daniel
DMartin at erac.com
Tue Feb 18 11:28:13 EST 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C2D76A.BBD3D20A
Content-Type: text/plain
David,
Thanks for your suggestion. I tried it but it's not quite what I'm looking
for. I want horizontal lines of latitude, as I have now. I'd just rather
have the vertical less squished.
All,
I've attached a map displaying identical data in MapInfo and MapServer, with
both applications' projection set to latlong. In comparison you can clearly
see that the MapServer output is vertically squished.
This isn't limited to MapInfo. Nearly any map I can find of a particular
area from any source (Mapquest, an atlas, anywhere) is similar to the
MapInfo view, and the MapServer view looks "squished", for lack of a better
term.
I've attached a map file below.
I appreciate the help guys,
Dan Martin
# Start of map file
NAME NorthAmerica
STATUS ON
SIZE 800 600
UNITS dd
IMAGECOLOR 255 255 255
FONTSET "..\fonts\fontset.txt"
SYMBOLSET "..\symbols\symbolSet.txt"
IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
PROJECTION
proj=latlong
END
# Start of web interface definition (including WMS enabling metadata)
WEB
TEMPLATE ../Clients/rosaClient.html
MINSCALE 1000
IMAGEPATH "\inetpub\wwwroot\temp\"
IMAGEURL "/temp/"
HEADER "../queryTemplates/query_head.html"
FOOTER "../queryTemplates/query_foot.html"
EMPTY "../MapServer/noRecords.html"
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
# Start of reference map
REFERENCE
IMAGE ../referenceImages/us-reference.gif
EXTENT -124.986016 24.403641 -66.490832 68.268767
SIZE 160 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# LEGEND object
LEGEND
STATUS off
KEYSIZE 40 16
OUTLINECOLOR -1 -1 -1
TEMPLATE "../legendTemplates/checkBox_legend.html"
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 0 125 90
BACKGROUNDCOLOR 150 230 150
OUTLINECOLOR 255 255 255
LABEL
COLOR 255 255 255
SIZE large
END
STYLE 0
SIZE 200 10
COLOR 255 255 255
UNITS miles
INTERVALS 3
TRANSPARENT TRUE
STATUS TRUE
END
# Start of layer definitions
LAYER
NAME "USA"
PROJECTION
"proj=latlong"
END
CONNECTIONTYPE OGR
CONNECTION "\GISData\Namerca\USA\Usa_Maps\USA.TAB"
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 225 225 185
END
END
LAYER
NAME "Canada"
PROJECTION
"proj=latlong"
END
CONNECTIONTYPE OGR
CONNECTION "\GISData\Namerca\Canada\Canada.TAB"
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 225 225 185
END
END
END
> -----Original Message-----
> From: Ed McNierney [mailto:ed at topozone.com]
> Sent: Tuesday, February 18, 2003 9:59 AM
> To: Martin, Daniel; mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] Can't seem to get the
> projection correct
> Daniel -
> Unfortunately <g>, the map looks just fine. What were you expecting?
> Do you have a sample of what a "geographic" projection of
> that area does
> look like? Canada's going to get stretched quite a bit that way.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> Phone: (978) 251-4242 Fax: (978) 251-1396
> ed at topozone.com
> From: Martin, Daniel [mailto:DMartin at erac.com]
> Sent: Tuesday, February 18, 2003 10:51 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Can't seem to get the projection correct
> I've been playing with my projections for some time now, with no
> success.
> I'm using entirely OGR data (MapInfo data to be exact). All
> the data is
> in
> latlong. No matter what I try, I end up with maps that are vertically
> challenged (squished). See the attachment.
> I'd appreciate any advice you can offer.
> Thanks,
> Daniel Martin
Content-Type: application/octet-stream;
name="MapInfo_NA.png"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="MapInfo_NA.png"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name="MapServer_NA.png"
filename="MapServer_NA.png"
iVBORw0KGgoAAAANSUhEUgAAAoAAAAHgCAMAAAF1CBxAAAAARVBMVEX//////wCW5pb////h4bkA
AABkZGQyMjKCgoL/AAAAAP/0AAC0tP/IyMgeHv/A8fpGRkYGTpjYEd+MAZnS0tL/Hh4AfVpNIEpk
AAAgAElEQVR4nO1d67qsqA70h7z/K8/sViB3AoLavVLnO7O7FUJSKS6i7do2iJT2Pf2Pfx/x8X//
T+iYC//b+4d0VE6Hkf//9+/Iv+Pb0eD///l8cxrMZv+v9f+nfPhw+dNaPuXyOFU/P24UP46PH9/3
Ap2GlHJ0qXwrdo/oT49SQbGJTZ0xgFaPhguX6UPlyd/Hy8PX7azHDVKkaqqYPeM/87In7AqyWdki
NqXjlLezQWRTq5mSbG2n9s5oaMhS7bMsM3mEnPakh6xapOYPQ9uRqC13rV0y6LCYq9VedChz30SD
TZNEHgkcVAx22Sv9aUvY4Ee0igndYALkbxvpLbJAmEFsEgwhWIanRdEkMwglmLaETyE+ZBkLai9u
/m8An/D4qGd92+gg9vkXkSxYpH0EGhQHlQRdBLmxhobsE2QQjkU4buKMJXSUkmKPGqwmU8ug5PbG
5gM6Yzj9PSg7xx9mUWv+UDCRX24oFcqoj4UNweDHl3QmuJKT8hyzsT64bax50W46R8H9mJ9TWRkI
wN1Js5ZleFKenZTAo6RHtuzduQ76Z8lYlQgGSeq3vBI5jaqmSprp0oDgWJOcBch0YnmYmS6G5QGu
uVzCXaVUS2j1UA614j1dVLpd2muej2WOx54x8Rfd+eOFQePxEwQO4LInrp7kkdYZ8pYEDuu4U0/6
V/D6kLPn0TntTu+AVdNgh3vY0w1PHcW9bv8AMJHpXLlcMFiWMcdy8Dg0FjKwSZdK11zc/rlIW7ho
cKOT2WWDxN7AdWkgEAgA5FF+o3tfW77s7kRdK2wpb31tdQG81dWmb6I6lxxozqx+l0+7vQrGJovd
YrTuh33ixg2qI+252kvl6gCsYHPYOzwHtljoVhVfeOTiaHWcd/kOSrdUlizCZhpbbIBF614M5sbK
HF2u2rGT1L1iE31A7tdsAA9Mg3tZZQrGcoxl4ZPlhQzKiy3h4iJtLGLCohEdt39k+dw03uqu8tDO
UnUEbJ0e+0iKwYaP7Eq4HhRDbtrcJIOZB3CcbX1pRom90o8+tq1dIHNvAThYeybrf1h0yu7AzsYC
XAi77zMIavLNjMaWjeJhrYwv3eqIWQzWfaWGhx+Qy43TLtr7wvttgkEy6iIPd5hyJCDdJ3KMjOrS
MKZvdOqN4AKJ7Y7AAaTD4EfauXtvxCTnC17Bfyozx/Y822Tr2MdSSPAsgWG12EtlZvw4RF3UPDyn
qGPEzlM96H587/BAqU3rVGHkma8M6Om4rSbaEyYEZjBPA7gJBUKOz2k0e5u2GoGQBGYQQvAwlW3O
HG3LIHQPG4ZWawHb3FZ3qiCY3ZKPprnmlml1UdgRdgStGMy7kR57ZAv4jK5EiTfAfAZZX4EDLzrp
XXDTgLPo8Ijet9OieQiPdpgjboofRzYxjrWQkOpBexnEErgdPIpUh+IslQk7VdjC5c00Op2lyy6y
va/ZW1Wx9RUIBGaCr2fw6a1O93XyT2DhWI6Tdd1898B2xY6XeefyH2xnnLsQx3FY9zw+1cfMG1t5
pno1BgLKi+dyW4iEh9Mx6meSJyC88qZr+lIFXLYUp3NI3Nd80WP6A6SC0wHvsIIy0D7wEHKYMEPF
zBk889J0kZHPswFNYbWns9Xcbu4QOcSTXcSpEKvpIfFBc1K6bnGVhH4AtVRmkZuCo+0m1RLNsLJf
UstkkMja5h4OtNhRUmi43gFA5dT7mKyk20nTrewd6CIls3UXn1TydZIZHhLdJ2FrqM5Axf1NXK+L
1q97J5LxubudpGLGUKMTMJztxrhL+25hU3HwpNhq0HXI41+doXlxfSzMt4PURjsdtOcuYZzMk4sx
Xh9ntWbbDvJhXKWQbmFiMxaNwlzrdtBokDejeqiM1IDGJNM4wCA6BuawfZPdwyse1cPM5HUHpSpZ
TMIpPrHIXpa1acuA7aCWQf3+hzzHSz6WSajho+GgLs98X1JzES/j7PGq5aPRScwhUh0paDlrXNzK
ikNXoyHTofkH3ALO11umg0dpwrkbqOH2hFnH6Xo1ZMkQ+IjXwwo3yho21a5o+1h5KL0gPz9sPICB
4yhtN4dxcM1VWkUs8lV+OVjCKc03NzjBVVoe53UHUX65o6nufWeFl4JoTdvSHoTkCOvf4vgDHDwz
vCEqT97kDQk31KHPcpD0lVSuG887fkcWz0PgTsnILsOQg9TVcpsIZfksenWbX3PNcBAmF30XhNEp
OJ3BoVG4UfL6LRLgYaeDvBa5xdnajelykeS0w8EyjEAbeTyZwt/hISGha6pDugOD5NT7Syi/8qRV
ucGH2V4gODPRQ+WmquEgHNIldif7B2cAe7mAU6y6Pde57GN9dFR3EKYwJeBgdfmOm5FA6lqfrsGQ
wfoG95i7BqWpdJTeVcpkD9n6Jme4rI8nPAEww1G7D/wrcKdDogOWBy/gMNkUPU5hGw8zGAgEAoFA
IPAuwKujBFbvavG8+Zd32u5ysF5q4NPis2Xg1znw4TLw33nXTtKFUCo/At3yga38aOhwAlxi1iu6
bKNx3TLqH2kigcemPiXLpk2+fAMPv8GfHIEtkAn+8X1wdOELPTw3R46dg9o62BAj1SYlut6mR5su
e9mkrx5u6BE+/HiesAUxjUj0uBBmEHaFWhB7fRKrbtqN+ijVAvJJdBe9PllCr98TZQ99TVnNPZ5l
D/C9R+Kh8NhaDqz2JrEek0o71WBwhWqplrIB7hkrcDiWinbhrcvMc6IPbbU8RN1M0UoxkzZktaK0
C8IoNyvB8AdGUCwRy8HG3j0ZD6s3MHRwbAODChpjzoyj/g7sDjsIhC0rCR2h8oTjaRbVTiad3cwz
Zanho3VIOpxApy+yT3CmwU4qDvqctL/r9T7kWs+IonWT7qDn6QKfT7n4WYk/3YjpgwLhFHKLDR/t
Pk/KZlZgw7knw4LlIQ4jxS7/ikV3wc9vVWGCxb6k0MwY7Mkh785iKfLwfNl1J/X0cYa26vcQ1OKu
7zW556GySsTP14JaHgd78mzVAT+JSOfLD84UgkwmMFXqHDpaG3EQNpcfe6rfqh4r19pV1hIHGRs5
vWCiKwk/R0lvivcBIfIFs9zWVh8CwcWsydhHSZeD7uetkFNdDraWYKaDDf/41bZdwU/MHAexhwm+
ZEEpf4Th9UV03etgWXgLpVUVliuXaQ4a5BVGQN3Mnz6ZnHNjj4c2g3qPlCS4l50BvZ5jTu1wcLdl
KF3FZysGifm9rnMctHSoPEaQPbQoHO22ykM90io1pZaDZpb9y/iWg+dhYcbDF0t+B7d83e5y0eOg
9JTRv2+77uDRU1QPz8RMcpBccyAmlNJ19WUJ0ZVlhwb5obMN0R5sWV85nNsD/Q66zn9+lSZXbC/X
CoOblGRpwdztn/l7EuqdMq2ksp5k8TQ8SNbJakXNj1hf9HDLF6i2R9ZpvY/qY2DuHvigmOWca9nE
FQePy3PtEcREf3thzpdSJpLlhMvBfee3C7QG7B25TR6xk/ixx0H3qi6Z785SB0Sw1TfooHMaOLSg
Z7jsMrvbuepgHj/q5Z2d4noPR7k/MtlBcNMit59vAHhc7AampulgrpPq/sM57Bgrh8IyMO0fY3Mn
O+w3HCyNkB2685zlIOr6nb+52uuPrnCY3L+SqNJyXho2HNwSdlCZYpVv5d7ThnY7uH/Z/zO5hcSN
eC1TiJuW+rXiYKq0JJXCPNyipW3CPpoOon1kkQDNwbRDcYHOA2ym6lst1vKJMghNyxQSzujBPcHb
UuVsmamqg7VUj4PUk8pJdrYhzHJzEV1wJsQq/NLhnqDBbEv2BR6s40Te1keSqcmHRnvIUx1kPqmT
1/lvvRmLnDmHheKWvbya6CDT25YnBfAoeu0uhbRu9qh/uoMYpNC/VuEBuqrs96rfQbVU7pH5DIlg
HxAd9VCD7iCLA75QCJs4/rnkorC44sO16iAe5w5vAHft9dS4g3wZtgugAzHx/rJ3m/ge9SQcw1+I
M7qDF50zGWQOCnSKDoJCMxxU/pSlzeCOPUSLgdozLmf3AJ36XQ7ihKZKXPF+mn917c39cjqY6nxb
/zPRQSbvHgfzuh1+208PJ/mHLl+y7Taqq0gczkuhXg8xMRKDdCj0xDDPQewhnSfAR36KzrswgokO
KpdkDgcV9/b92gRsONjNoCLPyQzCizvLQVooof+kWmqud9tWnuO2HQScSQ6Cy5DZ/h0+GkJjmoPT
Gy2wxL18xYiGOMtBMu6Acov8q46K46DIoFBiTXYVH9Ejw2qKyRx4h3+Hj3kyMDx80kHoq04hWB7M
n9+uepg193Gr7OM84qDwloAyGtZdg+3JX7jTjei6l4Fvtj/mYGn/pM8o8AIPjdtXTzvY8uDBbgI8
aNzVeJ7C5t2125zRfDDPPu9gAxPfFbUCj012gUAgEAgEAoFAIBAIBAI/Bn4TBxzxb8KwguKNebAp
L9yy1+7iv3snSL0JBm9DaCGQm9v0BLTyOcqtUyfoDfMdPp1dbte8B8pNRCWMzGU+Ve+Ng7ASqVwz
QB/FrjVqu5R71virKBTZKxTpmtzzU1skdmCX1a8/OCfxSzfeDP6gl49DcDf/Fk8lMBcDbAoUFvNQ
b7J+2IO6nEBwSqD0BUxKvtCUiwSSg4ppYE/gGovLapR4UB+UvplGX1tJhkUgDiTRnkofqIOniB3F
tkrlHYKsxmErZnsKh22NnA3oQ12hsLbO7eOvZrsJz1ejHKLnCYolJfRUByW5D29cGpr7shqAEcrF
rjQoULkJn1QWLzK4o5ZgaClpwTMndjTso3A0l9FkVJ75ZvXqYYPuTSgBeLX92S+KEErCx5dMoOUW
ijkHQnzOp7ic+DKvfEHrSNwsMIvsSyxOI3AQYl5Bzjf42kkSBPQ85XjzaVU4oLLwsgU81Zz/UqeU
QPp5BLVHyMONax7VwE3/+Se9cD6tvMZAXDaCw/YDmT008mivMOmo3tlE650y/OrXccHR8AD1FD+B
oL47PMsD8/TVFmhj/ogV14p2Er6KadrTXZoT2WUrklEyMPQIRnEpVy6Wk/fHYKqfC0KeZhJZTfAl
FaroIER7efLpyYZB4EwGxagnmU/5kWfYAqGvnDsXQGrTkDb3VGw7t4JFyefepnI3OzUjHBd3Hjxt
uaXXJrB6dAcaky3BBpfQqS4b4ZvYEYFYlJhG6dssAu9jsGNlo1wKnx/FU0qVarKKs1OCHn9vodC3
nWdHl86f8Qtc8Y9gbxiss5tt9BN4z2DYItAVFyqSzvc1kIvkXRrm4ODQCX+Ai0lsbhb2RgYuhJVr
daXS1EmENJq3rrqocRq3W+6mD1CiGh0U3TCBsOmheqZNq7kL9BkMVuN0aOxp4BswyB2/h8zI49Z7
WwT3Bi4oy79zPWJihMGEZhPTK3ZHopPDT+ka4hCHqwkc0GG9MWr7BG0fVAwIH3eYAQ7XEpir9/Pn
oDAbh6EPDR15hbSPUDiDwMkM8uBUs5zilPKb5/rmE7iv2Hdx7yp0kcB9T11jfL6waDGoetOtwsJe
95bqPQTSbSvPdUku1Ucg6sk9FEoPnbga9Ht1yUSxVGa9Ziz7qcQO87WBsdmraPDc1/Y06PNq/Cwq
mOj31lXZwMpidHdrK+2VaclD4W0Etq/LElvXOdmr4xdpSDbcorA+UuRq3OfhRRvO3gBXMB6/ivE8
efKwq6K889dZtsiw1brPxUs2/EqCcfjqtJ3rVGEuCvpFy/51H6/aL4VLEF2Dn9FGJcBNYy0FGGxe
FLU8HDvdP4OC2aPnTgEa+OwWvCrEFDp0aLfbCmCkmuzH/27vHWN4qVkt2Ncuvo5MnwX13rdQTzVq
DlVTvRjgr8oXzeoYH/6G9sc7Vmo9h+v5LmttJxx9Zshix1yC6YMpaLblPQjPd9jyYS57JxH9l8hA
gYDEdovtI+S815AbvTX1fls2DHtGQIlE1IwdXD+BYz3fsthXmnU4TkC9tDv+2/0COD7AGg4l+3ur
fDk8zGDHMjrBZ6jlG+zAkdGhkJEo+tK7s9I8IyfLkUSfH9yKRAxvZpxB88cXCwhkoZL86wsnV/vn
3ol9vSbFOk5g+YsmCoE9DBodVD4FIkxwoSoVdbR+9ifB+mGWaUbMYTeB5/aEGrXRr8Ty3lPVbeq/
LJFG03XPE1EI/3yW8Kzl2fSn+iCBxlU6HLlM99tBiqMO3mzCcvBbL8VzATwEAn0l4zWX4wrcyHJa
DKNvCJdBi5JqRzONmswQSgD9QBisTM5F7sPSWtB3Rc5CkE6RuKUS9aL3CBj83ImVJOQSmlHB89Ai
+lxdGLnoVhkx5iAQbtuD/SPBR7vpmozT7VXcHS66+INOeyvgk8wYPYCdKQQK8iVjC5g4snrxtdYq
6oqHXYTMIZAVR4+glilamWOQiTz44D56ym8pd0dDRswTCWx1eemmJSBQrVZIFC5315PHXF5BoNHx
ERU8nWWJalkouIUuiUGNjtlduGGMKRDwog68cBa+SXGcQDaYN8IfJFA+qy1AC3u2eMFE8ZwI+wls
QmHQ5lRPUaPvfqh7jsBuBVphmWcaTKsEagp8evBbSKBPm5QnzbLq0ePcndDiGCdQP2MwqBCoZ+It
/LHF10ICee+UaKtHwSe4nnlF14VQdzhWEwjKgoux7ARwJNXTmcinSUPgw1N7HJpEYCWMjZJAiKTK
2/jbhF3g9v7TFAL33fhrfMrc80b+xH30vsWfEyJN8iJRXw49TZYINbZDI/ycFp1Flp4JjSyh3bcy
qNwOE+VhEGgFz2up1Kn9+oYtvnGoonFQwVhrbsCohcg1rsDfWwnU/iroKgIrO9pypjAGvzzNkgkl
6wME0tj5+cRoQ3Y51y/nDgDHPaZAymPayXDQ/Eg+P02KFyn/X9LHEIESm1ibWrZS7dFP0zIAe40x
TKBUVu7Y+dvbhz0POI9kkG8s6GwClZHx/Pp07BNBV7/5aIs0KilKlEHgT/GnwiE8ThCUbEJCBmXf
/VdvZ8JPobgwlsj7fP0zBOJ74KYAzyUd3MfCZvDK+bmQ7sZBTP0okpfLwuezFWtnnZu8fwmMB3W7
FyPfvAScgMuTae3FC7z7CsB13lD1Py5BOK8MVg8G0zUC/uhEAoGvWQaq/20FTkBdGgXGcEG/fxz5
6cCn/QgEAoFAIBAIBAKBQCAQCAQCgUAgEAgEAoFAIBAIfCekXxawH9LUkt3myaNB0HR+r9jlGJ4F
f5w+4V/CeM0wszwT9ZcgUpLEtEm2XwXPjzrM6mLclL5UXhetPLdPCyfJhMju42j/Jsbwu5wlj5GC
oyAJwjtjanHWIvIBfVlPih+G/GDWP1KpvifcJQnHCb/2r57l+ssV4CFM385e2fAuChUCmQ6S1Kfq
GxYwf/hlEaV0QkMrTAfnT3hvgJCq52HzR4+gaMjrEPBcQH8vhxjkggXF5Pf/iNl7AUT+khIGOF3e
SoJeWwzNUhEd56VH7nmeTAFK7T0GFiWgr/Hj1arGWhGZhq8kL+cl8XClCuqv53DBW+kSIKZ7y++w
9hGoa+I8Wfuc2P1EtamN0VE0XfkrDLOQ3arBkeFGJZD+OF80DSJNe/5pOixCLLflvwt/9eE2tiRI
jljsVQJJ6Irpak8qihNltkqIBj/dfphCof1GFDKBiBZmUOMaEujmr7II+/M9cDVEuwiJTA4RRkED
SnRigLO2jyyVxNt6M+hMjsIWh9Yi5zBvEyiue6j25IUob5OuTddQiCLLjdjNaRTqsUAWmTFWZgcv
CGCNCdcfesN4hT6NQnmnI52DDSRQbNfir/1WDkKNuODjCbMb1ZtOpCtfIgwFzz2qIWxSGRwQZUZP
PyQGGkpUTHtj4E+oBomEbzUADi8ziAZwyFiSmi3hwFPEAYl5SXACg8DATsdGckmsrqyLpdJdikeG
M+MMCk4Cs0qTNI3EC5PAs1A+fzC105q1cHaSh0tnFFgCHG74c5VAbMFFmEggC+5gSXNVgqQXcARb
qexShgmBSCfy5Wb2doS/rRrRhqsOAv1ksaxnojY2EVGBgf5POz1go1pF5g8ONVcvEjiKRr8ozv1b
g0gEAiFtoMeB0YykNtUBMYsWN1zs5c+0UcPfJwhUe0UmSFpp4HKAwLqrVRhSNb5RdX6Ol+ByvwT2
NAKHV4S1+hB5tWnVG427XFIsDMxY7QryFPfImFdGIJ0cgsptpgyIXp0DK7gaVt1P0lBgBXueF/fB
GYOlNKWUu5GS+Xq4ZQTuvoUPu/Nx0aR8XtqmRZTYVrt0KNTyRqc17SjS0YZdFI+l5XMj6CZ/HXOK
7tMgPKK51IDYYMp/X8QRtNzpidtuFUoOTQnJPn+1CdIYRJM9ZWP3TAM91q/A7k6mxnXRhGJYamnr
4E91lwxiw114DoG7a0AcNIo87NGfxmCpXAw76RMJPEwuCneq2fIZXJXIrEECVQa3eh/LmQ6VwIkB
r6EQDvLNgLFGjV0tWtrBn6bABQPY/P4MCCwrTJG+UtjsWLl6D30GgQumAIcM+k3iywoeeR0r91ZY
gDj/tZxpbUaIipeuXuWwtW30z3wSBk/zvuZ6pNcicN1ChHvcTeJn2NvLoIWOUw47E9ZLYTO8nrgu
oH3JC3wpRGx4WkUkAQLFe2dmU5MIvJHBRjtUQoURwEYqm4mJbL0IvZrzjr7MInDJdDzcThJ2mioX
CS9DCFk4akXQdbqeSeA9DHZtcdEgMkc7j+/Uq1wF2iwU9vHXJPAuCbqaEdV00AGIZOsYOXLckfEA
MZPAmxh0tNIMj41+gCjwhVFYNw9aT/4MEXgPg+1G2qHx0W+TVzGwAp2G9CvqCwTeMBD6NrLtWAg5
5DqlEsVMjXZfJ4Ge+C7DtYzpCSxXEJMvGVs2BtYmu1npQHsh3RPVSUj+V7ao0r6EwNULmtblVS99
iBTZpE7hGgKPC9C0bKfGPDubvx1fD15AX5Bo3p+KhgLH2bO9zQTiOWUVgb5ox2A/gDDK3/G4jd3w
yTMkfTmBCxg0CRzn7yDEbJcu/Tp7tbTOfB0GeashquRx470tFutHxfnyAaUGTQwRCFhorZBYva5Z
Py/w8rWMh4me6GGpQRODBNZPDd/RpCHsmLUaqg9MDWvwzQS2QsJknXT0aBB23TT4oPRaAkdu9WR4
d7oBF+1dH4HCam7omm0xgVcYbERT+x5aMw7MJBUDA+FqAs8SXbzB0BwBoNBHpv9LDL6PQBJawzBh
ebAfn2GMMDiBQMfTTN0MllskzfGBH8pn/K2lvE8wwOA9BPZekRzjWpNB8VS+u9TXi4Ga+xi8i8DU
dZ1wbqcWdXRg6AZnXRJ2a/CuLpyT66PxfCJhPz77IilN1Qa7GNyLi10M3qRA1GIzNMTzSI+6NhV3
/aDjllmYlW7FVghI/QTC5UwHgYDBYsAdT7vUdROksBlcoS9Zr/XSGhjrwxu4OV1k2BFQo9R1E2fR
BD6qEZ7n9q1/DqnKGaMwW3DfALl1DCSNqSHCAfDCtVU/g1C97yNQbKoMPJoSu02TC5NeBksnds4k
9xFoby4LLPbQdxRlG6NWdjQC8+jrnInvItA5IOM4PK7tOAW4mpabFofZhVmBOX93eb0Z3JWcyKHm
3kfO7oVHJ38khw1HbiHQScfpe+/k2yzbpUHcidvB3UFgR18ckaBvy6uPwA2sClutuzr6hQi6qJhO
YB0VnSQiAj1jsW+quRJB23wtW6LouYIzQsD8NS8hC4OgM3sYbPrakrFlvGWbuHLe4ui6BLYIrB+P
704NAjW2p5J2lIME9tEHRvu+PQSskkaobQLxnf05U8kogXY1wQ00APXVYx/lgg4CK4MJouWCeboR
wFg10Q+Q+b6K+d/WnOJhEDzz5eNvb1B4G4E5wt5REKymdex+AtHzJe1BsPignmrVHKqmeTGiwExh
SjqHI/szG7gm8bignWlVHKqmWuvYSCA17fFviL/iTNmuMD1Qji+pppsbEKDD4BUCD3kPX7XeS+A+
mcCUhwXnMkZkL48QDgqlgwN12tUGLA6ZyvNS/TxOoWvniZf5YgIrf+rLQTwM7n4CpbhfT6A68xbG
jkXM0OtqK3Enlf3eD17q3UYg4KkMeHjKqPc6BhisqwIgQ3PCZ0daAXQddqD3MgSLhbMEOuE2RONJ
m280nEfgMIN9ezGJRsooOjcEWMfupNDPIDk3TOD4QsZdsKpK6b0beRR6uCdLKlwOK+yuTqAags/a
Z2IIQ7CpBMuNUaj67tj3ouVbZ0Smmvy6/Uj0ZdUSM0I7KV2i8EYCd8RhqgeyO5oBlx9ibn6OwOox
QPVHNuPd/DiGpJ0bxjGL7gwSmA3IYc8iUCOFhakk0+NHEjcAxZATWMWVd4oPEQge4JIJ6Vo/GLFp
Idf17vlB7seuDWCyPYJZgU3JWEWgn0GjpKxAvE3++bjLt4A920Z8OpT4g7FjNscI3LKW1aj9DPYR
WLxm7g8QePK3o0vTdN7QO41KLJ5NXyKwuXGv6NPFknoKdZ7a28oRXt4wno3QthL+46UCS4C/cQKb
Uc8gUFg4kNTgAaltAdWDBRI5V6Vu7J9eUqBCEOwLOjWwQsc5dCkFm0nkLhAhg/nIeZMWnZd15mdQ
8t59HWCAliTVLANSUWYo2QQqmwpTCOSe78QpIfUigRah+ASregpv47sBuG6qKzhsSOwviep5iQKL
X0IHuUSgTplyLYDWFVuZAZjopFQjncKC55FV9G2bFbYUMhj9CbHmGIhJkAoU/s6vB3dJWChIVxzE
FD2zkD/n9QMYbFRcIPAMDwa86QwyjtgQm2/Gg8u7FeyZBGo9RydJPSMYExj5OFPzlP3jbZYDmW0+
cZTHB5aS10NgXa/qJKlnhEGQG8fO1J1QUhgSmjmqtOc1Oey6C9nrIrBJUweBnMKEthGybOSxDVvN
/98RXXAkheHeSKBCyCQCWa/eGIEJznDiWFvWDokNdErfXbMM7CJklEAB6Dwl8MMpWEgBZjCB1TwW
xvLOe7bzIIFomcSdSZA/pRYgkId2A39zCVSgbW0zBfIlMzQtNJ7XKcJgdxdM1fQSKC9bw3EAABh6
SURBVB7k3VUgSCIw5SW7aSHjIf7u6sLN+DmBh3bPc3L9Kr+fJ1BdE+F1M1+0nE62llSDz1nNYbAX
QwQ2V5VJ4s/wD5CcpfoUgR4WUqvAGIEJTxMUG33QgFrDNP42gcoWFvxCyMlK06knu33fQuBgH5cI
FL/wy2SZQETdTxHYmC9aBAqLPdmhZ5Wn8Oeeevs3IWym+wgES8RH6buTwMaOVncX3h/n7kB3F27Q
ZPdx3Wb/GHj1vfKzoAlhCYFKp7UIVA29RIErCHSe8czCRiJewt+dBFoMkr1A8jnlJR/k9GnmMm4k
0JhI+NbVzhg+KHwZfcYm3CMEAo7g1Qm5PnkVgWwjWFp3zSJQLVv5A0TVYm/mD92OhUHcSWDd2ZMK
w059avNpzjAoZY7l9RwCec+UDAnz8tOMUbQYXEbgXmZWvQ02SH8BgexCaxmBeYUiGhJl+Ub+pK19
13q2GwpNciKkdxK8lL8WgwsJPNoRWlf3JL6FQGGRodBLwjPJYoyOpOFpsiTo4riFQNGYsiR9J4EG
g2KA7Ws+MyOAUJk77dx7JagxqLyWYjWB6pn3EqjcZFc7oxye+FE/aLAknng1gTqD4lE5PJ0r8aDR
ojKUvrgP6wwuI9CebKWl9JvpU5+UsZc4FwgUrnaFI5DBV9O3aT8YHyRQNCV/E1ac9Ar4NPk0Qw3I
487YMqZ0UOM8PyztUedvr6fvfEKCRz2kwHyAjGuiCYlAaRfmaX68oJFKTDkJLLEfEkoiazKB9Gr8
aVY6kNA7cwdnYfm8aFfeh8YlnuakC/Q3B/MI3MX+rBFYTnyX/s5fCCQQ8J0EfuXsK0Ee+a8TKHy0
CfxO+gBEDpcRKEy+TxMwAcKCDl4b2GJ1EIhKkPK/wN8H9Jp0d5MmMygvaKi0f4e/fyBqK7+JHiMQ
HEMFfpjATX7bVCeDhMjdUuDP8SejqxsnuD5K59YfHEph0T9CYA+DdIwrZELWBJn/OtwMsklCmcSP
r0FgB4FbVjKS49OB3YYECTEJzMNeLQ/NkL9D+4cIRHODwR7pr4xA/Ov/vyRBMGbpdytBYXOeqPze
5f8LkCBBIn+sOH7HJDn79xgEPxuXth8UpjRbeZRc4OcXQLgxNWjhb0mwgmxR9bPw1wnEd1Uu1P/D
BF5biqRg8CqBf28pSHBxHq0MznXre3CZwL/eh7eLBASBZeNguPofJ1B9kaS7+t8eAw9cIvBQ8Ex3
/hrS3+7B1/GntvWX4A/dV5qPv3Vfbj6CvkAgEAgEAoFAIBAIBAKBQCAQCAQCgUAgEAgEAoFAIBAI
BAKBQCAQCAQCgUAgEAgEAoFAIBAIBAKBQCBwoPWy9539iQGMB71mf1Nmw+6Yfr8hisA/5BzYItzF
v/x1OYH17xA5FeHWkh7WcVRtzKFSfqJZJaBCTZQXKAsDbePsFYOqp9Bf9HJrVC0df4ij6bfcgNTJ
GrBKjmXmT2BYfNfZlrNYbLPCpIruTa7Q9p9744jS4sKiakK2fg8GbVbi9KR8mJYUqRw56jC7kpfn
iVJSd2kT9Uf/zBhrQoyVut6ixWLphoR+GUxOW9Izi7AawoAnq4TnKVtUm6d/VnVjI3tDC2I4Z7E9
t93HjoZ7EvsVUGWk0tuuIqpDEI6uQPEPvWjKE+rWuRWWNXOvWZUcbwUuRmuP738UbvEB2lypkA2U
j8ysVFz1uK0GpD/491FNJszFm6NZTX/CX6EKGR7wpRMMSCPaE4wJuRCz6XEeVkBGeYSGPSMs7GJL
gDwy+2+2hgg3lCXMVaWMl0xoIu0QJipoVPUkp1YWsspTrVs03ReidiOxv4uOhmS/h38BlV6DE2PH
1ZmSnjWn02vipuaUnuFWMOMKVEOjQpywpf/9cHbEEd1B8juSpDnA/aEHlKYMm4oIL0VrBIds84Z6
8vbHYKeilSl3EksmeDpaKTI80Ksq+sM7PD7X+8ry/SqKmdl7CnODsdjiGM0Mywpr3/avYdSICpXz
u0sa6K/zSzIs6/D8XYlEHGLcjbgBmR7OKIzBcrqVfcRD8zmEhlMsJK8B3ebnoxj3WJpuhZirOm0m
srgfD01IlRP+hLDs6MPX+SAE34BW05y3anbR1IX4rgRdigoW1MgXQWvqHzngajQzJviqMADigAUE
O2bELV77mLfNWBfmLA7+cBT3yhPgZjwrNoa+oBV4tDMFnrsBKDolYCFwL0mNwAeYtSl350J2pBGZ
UcKRjKaKd/QNmqYuuClR27oFvD3KpHXn35lyYTvAkX9pDqfwE53HZKW62Hr+0KqBnTRCsy9stKh4
S5QVgaIeZpr8L4TRftPprhhbBHgYKczsmXKP5RGQBCucwOIWb8QCasSjwFJnlwrT74bDXp7UmXE+
zHR5vb8Mo60yBJeSgpMy+SNgo95+JlccYkot4xnW7DZZzp7VJEVRmSv3L4RjaliOBFASVivvRI8W
1qGrUSoWDVZCSDmSw/zvnkcCnwEj2+xUdRE+hW2GK7qaZFFK8NKqtrcE17QwC+5GZQEYD6foqWiy
fUqPG8W11ecsuOdCHI2Rs5bmqWN+++IeonidFqX2XX7OhZcjhdgm9Zp5d0VWv+TF6Tlvl8qmFTZX
INNjK7I+BxnuEuAjEtxh0J4yDY2MkC8Ys2x8cjLKV02py0JTAcxIwtfvUhFPk+qdylUCpJPF/eiR
jNfUkpiu2h7oHg0FtrRygQViepoSm02tyV0bsxq/RYKX6gsWtZbsXJraaz1g5HBUwBIBiq0NuT0B
Exx4QRRuSJRPybY3/IT+gY4x/+aI0M2Lr+AiXJXQq/XHevrsJHdE7xxzEiq5XoAvyd41Gb4jBgk1
j9IAc5v4oC9Cn9AKXXKvYwS8lv2ZeI0jLkjpbBeald8L6mMPP+UykxYFXQLM7b5oGHlPh7Ch6MpR
ZE6KuziiDXN/5zq3+QUImu+rshjN7L4Lqs4SWf01f5IiCw1oY4gSpi5iZbr++gT47uRmvFyEkvzA
Dh074xbfvM5I2xY9noR+10Yiuh1XU3AXmP7YyXa+9TDHo+dqaz3MeJMA3z68QIgDwvXhYbaDWUNW
GTPtrG4OLqEPQ84t0dwlAULXBuo+jydVyfcyNA3JbusK9GDU57UiHPMqezZe+424rkAz2VwSSEBG
+V24OtAlmJ+f3cDPZouh/uAWK7DbH+7ZBRMvxJWA9IFHf6qEFQW21LFN0Z+WZG1Pj/m+iwrVG35W
gNW3i0ZehUnheHQDtYOUgYvbdhxtGC0p/h732qRzE6V3YArRV428CbPCodsq7VQkcJNBK6AOfl6F
KPrbpS7Dz7gk1YcJRP+WBOcH484dTfPnczv3veLAEms+Rt3RhUYwieAJZl6CScF0DkwSrluQB03B
dvNZ/vT5deAKFc4g+6fm4RmRYN0Mpa1SKukPH+FqEU7JLdgqZAX742jiMtmI8TnWHsX1KOYkTNQT
OQW+8rahskoFxSNJi7CNZfKbJcDveTiliWsRTBwtVBMHyUiAzAv8L3at0SjFVn8rvQIXyNYTMNno
rZgiQPqTybmgSnKT3tU5BCGuwAWy7SjnG74H466vTRQGaaeD8G4fv06AOcxFllfjgue3yY+iq8Oz
gc3h9fdMwVqY3zMqXhsBV6VJxfBP4++ZYNsYJNsf4A7/WdbaPIx6+UwWP61eoRbJT5fiuugG/R6N
9cbmBjHo5JODSPdLNxTP9cFw4SgpTpWBESzJj5Y2KY29uqOua1EsDfG29Pw8FiTHyJlwqH/k8/i+
Oki+dXc2df+ibWJzF0yNVb1NgKIQLqXKIcCVTwSm+gzQjsRYWhwNbISJF5gaFuB9CkTf94v6s3en
kTKW7HQWmVHB1aPDofUz8QJT3ybAq4OEPsHW4zOe7WlGxcIQRsW1+GYBiov65bg6R1FdwacV8IDE
C64KJtHGavvDcfrpeIGpSwnNFtYpUHsyZtxnUDfR1GPDqyVoXBLfson3/QIENlZJ0NommeA1Hnd2
Kk60FFynQeROmYKXS/AdApylwBXJgSB//fCSBBNItl0IlV4kQqj/VFeB+3IJ/pAA1yuw3r1AiRu9
i9PxNNf5eeXDP1jr8PmqpRL8JQHCWXhBmk6Tu/Bs/gTfzahqeAsnYjjrQqy9Gvk5AQqYlyGQKZy4
Cc5bQfEYZ8VEAhQVuHRn8JcEWLssOzQhadVIwn8wYa0AgfU13YoHSTYDwbEFgf6SAA3jacLQoQ6s
K51HWb9BgcquDGl/boAvMLUwhYivK4kjyYcD4mIB0u9rBYjeSogv1tGReQFOsvRCAUpEDaePCHDP
F8VL9cfTfYcC8S6nMBpOVOBrBDg9iSpJmM7unKBaM8cCfyD3iZA0iJczs6KbYueiqdlpdBHUmcW0
7Tt6LGFiGrJDmpvXvR8ACI8MgXCAvBzz7wmwj5ukoZmbyU6r44p1eO1YWFpG+oNSnBD3rwnwKjGA
Yk1204c+/jAKaEJrq7/b9AsQ/zQggcuT37oImbUInMiMkMxF2qvtQe05tZ7PEhXuop5mSBK49Esj
4KynEeZJQxpMFmnP3tjoaBModrrg8vBKO8ZVTn5GgJPFIQyA24LLjtrYxeoEy/RH5oHrfPyGAFfo
gqdxz/xPbumK+3RAyoemvdiDq1rQ+zty95AAF41K0hyclm38DQYhaWD2WOgS4MXUp2Q+Fek3dM2L
wWrrHtNAT3WdOVjV4FAaxeSXI5MUKP1GnorvKivXB9J9wiw6UGXtPWTM/PnvmjbLMNBnvFF6jgDp
22ElDZZL8WEGnr6e6aZ+pfp2dSab0lXt5sQT4zYnCBDITVdgdvT65dSF2tfavrE1bxN4GtZEMrM9
7bbvsL05AqzRwwPWs1tXKBjucNeavrG1jlakcWBZ23QQudbaZAUqL1KCpMygZjjmXxQgzuGcXu5o
r7RQstqLamzum7P13dGpzAzZuth4Z/WbBHg2RTZhb2pztK2Ulr7ayFbgNAK6h9OfFWC5mpxNsqfZ
/hoMywVI5oYEh++r8XfY+GEBwtXxjQLsgSi9O/QnXonoV/UjYfnLXmxqYfEZKB387obbQFLLSbtJ
gCom3aRyW/l5AT7UaAt0pCP6u3sNKAhxToSeYhdbWVh8DtY3mvh7AfO4S7JQ7j1gjSH5LZcel2Bl
qh6YJMIJRRrVe+r/oAAbA4kGpgRi6yYFsi0C3IOANkfJmVBkYv2fE+AhFuN+K8i1oQOmP7A0XCI9
2jx4sIV2lTrAD9EzocjE+r8mQHmssoc7sXixJo6oa4QnuZzdkDFGkF3tdgHer8ElLWJxiENXHUAs
EQFGjPzfJ0Hk9I9iJNfXtHKhtmzwA5q2CimpZt7lFurn9QJE/qIwfws1rt21OSdZ6NdLd52GQ+Yd
5rOEN9/m+j63ccdaEDo1RnoqY/gQtV77V+uIopSrUgw9XD+TD09WnAJ0JrfGfhfGFfglAuQlqg5B
uEB2lJ71bjdcTeLxHc3O3kR7m1wiNs0x6WLYxQ/4Zz7WCLCUU6Alzu3NLD7k3uHzWcyy5hjauX5A
gKiT91Cdy/lz04chs32VIN8q648IEDV5fqpH2vqjhxsSPkx3inoaUKD9AlylwDGrHbUkotUEeHmZ
QYakCKHQUVJOKDsBpOUR460C5Ar00oQIu0q7bn9BrZwL9iZnnX+/AgfcZq7xdZFcUHG07hg23gEj
qu9/2+NqGgCMr2sAIWxcI962P7MW6+ztAUCXgWh9wHHsGjNjKFDRofATIb1M/VXp0fy9Ahz7LT+t
4s7QoP1ZtcQ+n6uhi0u9WLuFAb+JI4zdVixCUpW7d7QcFkJbtdMxoh2pwkz9jRprBgLOw2UWt4IP
98iwS67Swkd0yG6JSrHo724xDcFFLQ9UKOFh3AeZ27YKGk4YYpOstr1QqXBQqswbQiUrXAKS0Hzo
1SjhpToDtGcjSsrnwIJ92G40bDZbHGvetqqfdB3VLPhce1pfTSQgwI6EklOt4n0YM2S27/LuUwam
TkonT2+DJ4lUxR39qLjotlP3DerbRt+mw5k6aR2wJVofrGYrwWehpA5JppyEzKG3crSN8m+8lGHB
N0Z8kfY+GEq2xZRKfxf6fTobGzgleLvJ2y8ktTXVPp+Ho8al8CgsF3pITf0YybXBFeXx+AqPVd6E
Hdd2KpqeWU47qoPsSa6Q3JYKbadZfJQnu4tUx7BXjMQHNHQJA7luUD1BTCsE6NmspPqTiyDyfGFK
BRLplK39vq0OfezcV0rvwKAAG3mUee5pobuOq6JLgwYxRQi5CNxXNFqUWi2H8llSRhIXNnSc+Frp
HRjKdU+lVwlwd2zHqLxQQagSlWC4mj/JQxtLF9wta/8KaYVmZmIs1d8swN1cQzgEWEqxIuKAtSnb
NPlgPVlsZxuN38HdJJGlsAYDO4NLyl6pc9bzQjVQmdH9SuIQ+BGFv7kqZuK9I2e/ob5tdAC8Q4BD
StKVxe0rx13UiLLq1HomBhT4KWm5MKi/VwnQl21uXzvhIkeUfp8PO63w9+Q3PAO/awo+cziafApI
jtkgN9P3cFur/T+BXxAgrtflmCUAzZZUGh4Z9/Xvyc/3g5XrcGsCpKK7zkBNSwOaIRRYL4uqoeMk
tfsXMCCnfqyVERfIlbLJ+dMdSt/uXLmixtk5bP1PoJGvHinIZd8pQLVruFREFOV2F7SJ6jCjT6vi
RvyaAH2VFfUptdkxMpz53eVjnYynVXEj7hDgBLidcLqsFhJPTCJJ1x7JyTNSeAQt7q4L8ILBsToO
MRuSXi1A0cOnVfAcmtR9oQA7LwYcbTWGYP8IndjFytMCeBpN7r5RgA7B9J1sD4A9a8Ad33D567iS
rJGygwIcwogL/QI0B1QhiL+542zAoq9LLq8ZAc86lgJ7p+BGQ31dIvSH8LsCHDnbJUAy0mpDMDqQ
Yvwj6B0PVLxKgK2pUTurCFA4zA9CiVXN8XHw6Yy/DQ0F9qywJxWaUKdZj4xeah0koz3hS1nFLG4i
5NdEc6xwZPt9AmxWU4Y1+j0pu3dSXXxcGAGfTvVbYavMp8FvE2BDf0kf/8XDXJUx/nVA7deASzOd
3ydArqNMgTHMaZa1sqE/J/bmmwKbGvw6AdJRC2vFqi+NdWYToT8PGgp0XFgadXsKTajjrlZC8gzy
QjX9egScDPn54Jtnh+4wdBWaUMdfDY16bssUjpJPZ/cb4MmCWkZIy9PoUpOnMI7fUadYfzq1XwNP
JuR0uXLoT3Rv4dHaVVBrO8PTif0SeHMuaHCJAGVcq40sTZCWD09n9lvwyYo7vyTXrlou60Zht4lW
wSxAv0OgopOnUGA/3BKsGnTn400C7JCRVK2Ho1BgHzrSchTtKu8sqRbuyv3VErT0gGTLLZWn0/pN
6JRg14DQkbprAvTNwX5beM3RVy9GwE709PRvFWCaBWcbT+f0y9AjlW8U4CTB2UoM8Y3D1cG7VTFH
gE63rEKCBaE4O2S1TE7F0HcVVtf2JFQp5ijVKGwMSN7GfPqTDrYkmMDHpzP43agJdshw9kjZLszm
xQS3hJJ9ca5Ml+6CtrJj3JsFSKSpQbeu5gkQFTOgVHC2phtQXAv9LcHxuKB+bfyoAFENXL1Dap2X
PKrlUN5kZEoT+GvI3iz583m9cIeJnhjsoY4fezRXv4zat4WUmKsiXz4vF1ZNOGdmXYA9V73PJumn
0XojrVsQvoLdhTtMdMzLzb2c8iHUdx+A7OD3YUFMKdxjomsZ0VRgCvk9D+9YqM3f7pmyE6oApe09
1YS9nx3iew+ayklks66BtsIakIyIhsf0Fwu/l0IV0HFsgdIMhQia8ZQzi4OzT3MdUGGNbbzgsMZs
MMtyU8Mz8EPcBuZioQSJZWXszR+7VgKhv1/CKg1Sq4YCPSDFn2YtMBMrJGiaPBtMqb6ArWys6JKF
eJqywFzMV6Bt0TneSePoHlPwD0IYA69J0h5U8VjG/mJM0SDTY63+DE+BVTAmvzH1WcNa++kpNNdy
J0KAPwigEaiMbg1iaXENog1J2xv9rwiHAn8ReGLEx3vU5zDfFKBYORT4ByDqwqdAh6SA7rr0t7Fu
EAr8U2gpsHtEG/OBLiNXNhd4FSwFrtee6EII8E9BXQjeo74tBPjnISrwvomwXEaHAv8qhB2ZOzXw
bOuBN+DZWVASYCjwb+HZSVCahEOBfwoPb8bFMjCAJfC0AkOAfw95z/kZAaRnO0DgJRi6nzux6dBf
4B8eyX8dgOMaJPAMTgWGAAMP4aPA0F/gETy2/Az8YaTydH4WX8gvcD8+74t92olAIBAIBAKBQCAQ
CAQCgUAgEAgEAoFAIBAIBAKBQCAQCAQCgUAgEAgEAoFAIBAIBAKBQCAQCAQCgUAgEAgEAoFAIBAI
BAKBQCAQCAQCgUAgEAgEAoFAIBAIBAKBQCAQCAQCgUAgEAgEAoFAIBAIBAKBQCAQCAQexn/1xSFi
5xNiJAAAAABJRU5ErkJggg==
------_=_NextPart_000_01C2D76A.BBD3D20A--
