[Mapserver-users] Can't seem to get the projection correct
randy james
rjames57 at yahoo.com
Tue Feb 18 11:44:49 EST 2003
Hi
Not sure if it will help, but is your image size in
your template file the same as whats in your map file.
size 800 600 (map file)
width="800" height="600" (template)
Randy
--- "Martin, Daniel" <DMartin at erac.com> wrote:
> David,
> Thanks for your suggestion. I tried it but it's not
> quite what I'm looking
> for. I want horizontal lines of latitude, as I have
> now. I'd just rather
> have the vertical less squished.
> All,
> I've attached a map displaying identical data in
> MapInfo and MapServer, with
> both applications' projection set to latlong. In
> comparison you can clearly
> see that the MapServer output is vertically
> squished.
> This isn't limited to MapInfo. Nearly any map I can
> find of a particular
> area from any source (Mapquest, an atlas, anywhere)
> is similar to the
> MapInfo view, and the MapServer view looks
> "squished", for lack of a better
> term.
> I've attached a map file below.
> I appreciate the help guys,
> Dan Martin
> # Start of map file
> NAME NorthAmerica
> STATUS ON
> SIZE 800 600
> UNITS dd
> IMAGECOLOR 255 255 255
> FONTSET "..\fonts\fontset.txt"
> SYMBOLSET "..\symbols\symbolSet.txt"
> IMAGETYPE PNG
> # Projection definition, consult the PROJ.4
> documentation for parameter
> discussion
> PROJECTION
> proj=latlong
> END
> # Start of web interface definition (including WMS
> enabling metadata)
> WEB
> TEMPLATE ../Clients/rosaClient.html
> MINSCALE 1000
> IMAGEPATH "\inetpub\wwwroot\temp\"
> IMAGEURL "/temp/"
> HEADER "../queryTemplates/query_head.html"
> FOOTER "../queryTemplates/query_foot.html"
> EMPTY "../MapServer/noRecords.html"
> END
> QUERYMAP
> SIZE 200 200
> STATUS ON
> STYLE HILITE
> COLOR 255 255 0
> END
> # Start of reference map
> REFERENCE
> IMAGE ../referenceImages/us-reference.gif
> EXTENT -124.986016 24.403641 -66.490832 68.268767
> SIZE 160 120
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> # LEGEND object
> LEGEND
> STATUS off
> KEYSIZE 40 16
> OUTLINECOLOR -1 -1 -1
> TEMPLATE
> "../legendTemplates/checkBox_legend.html"
> END
> # Start of scalebar
> SCALEBAR
> IMAGECOLOR 0 125 90
> BACKGROUNDCOLOR 150 230 150
> OUTLINECOLOR 255 255 255
> LABEL
> COLOR 255 255 255
> SIZE large
> END
> STYLE 0
> SIZE 200 10
> COLOR 255 255 255
> UNITS miles
> INTERVALS 3
> TRANSPARENT TRUE
> STATUS TRUE
> END
> # Start of layer definitions
> LAYER
> NAME "USA"
> PROJECTION
> "proj=latlong"
> END
> CONNECTIONTYPE OGR
> CONNECTION "\GISData\Namerca\USA\Usa_Maps\USA.TAB"
> STATUS DEFAULT
> TYPE POLYGON
> CLASS
> COLOR 225 225 185
> END
> END
> LAYER
> NAME "Canada"
> PROJECTION
> "proj=latlong"
> END
> CONNECTIONTYPE OGR
> CONNECTION "\GISData\Namerca\Canada\Canada.TAB"
> STATUS DEFAULT
> TYPE POLYGON
> CLASS
> COLOR 225 225 185
> END
> END
> END
> > -----Original Message-----
> > From: Ed McNierney [mailto:ed at topozone.com]
> > Sent: Tuesday, February 18, 2003 9:59 AM
> > To: Martin, Daniel;
> mapserver-users at lists.gis.umn.edu
> > Subject: RE: [Mapserver-users] Can't seem to get
> the
> > projection correct
> > Daniel -
> > Unfortunately <g>, the map looks just fine. What
> were you expecting?
> > Do you have a sample of what a "geographic"
> projection of
> > that area does
> > look like? Canada's going to get stretched quite
> a bit that way.
> > - Ed
> > Ed McNierney
> > President and Chief Mapmaker
> > TopoZone.com / Maps a la carte, Inc.
> > 73 Princeton Street, Suite 305
> > North Chelmsford, MA 01863
> > Phone: (978) 251-4242 Fax: (978) 251-1396
> > ed at topozone.com
> > From: Martin, Daniel [mailto:DMartin at erac.com]
> > Sent: Tuesday, February 18, 2003 10:51 AM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] Can't seem to get the
> projection correct
> > I've been playing with my projections for some
> time now, with no
> > success.
> > I'm using entirely OGR data (MapInfo data to be
> exact). All
> > the data is
> > in
> > latlong. No matter what I try, I end up with maps
> that are vertically
> > challenged (squished). See the attachment.
> > I'd appreciate any advice you can offer.
=== message truncated ===
> ATTACHMENT part 2 application/octet-stream
> ATTACHMENT part 3 application/octet-stream
__________________________________________________
Do you Yahoo!?
Yahoo! Shopping - Send Flowers for Valentine's Day
http://shopping.yahoo.com
