[Mapserver-users] Can't seem to get the projection correct
Martin, Daniel
DMartin at erac.com
Tue Feb 18 12:19:54 EST 2003
That's the output "map". The input projection is stored in the TAB file
itself. In MapServer, I believe OGR takes care of determining the
projection in the TAB file for MapServer. The projection on the LAYER
object can be omitted without any effect on my maps.
I know this whole thing may seem picky. I noticed it right off, but I was
going to let it slide. But the first thing my boss said when I showed him
all the maps I've put together with MapServer was "Looks great, but why are
they squished?". *sigh*
-Dan
> -----Original Message-----
> From: Ed McNierney [mailto:ed at topozone.com]
> Sent: Tuesday, February 18, 2003 11:13 AM
> To: Martin, Daniel; mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] Can't seem to get the
> projection correct
> Daniel -
> I'm not a MapInfo user, but is MapInfo telling you the
> projection of the
> output image you're viewing, or the projection of the input
> data you're
> using?
> - Ed
> From: Martin, Daniel [mailto:DMartin at erac.com]
> Sent: Tuesday, February 18, 2003 11:52 AM
> To: Ed McNierney; mapserver-users at lists.gis.umn.edu
> projection correct
> Well, perhaps MapInfo is lying to me, but it says the projection I am
> after
> *is* latlong. It says: "Latitude/Longitude (NAD 27 for the
> Continental
> US)"
> I've tried NAD 27:
> proj=latlong
> ellps=clrk66
> datum=NAD27
> no_defs
> But when I do, my map simply disappears!
> Thanks,
> Dan Martin
> > Sent: Tuesday, February 18, 2003 10:42 AM
> > projection correct
> > Daniel -
> > You need to know what projection you're trying to emulate.
> It is VERY
> > unlikely that any map you find in an atlas is using the "geographic"
> > projection you're using in your map. The example you show
> > from MapInfo
> > *might* be a Mercator projection (which you might commonly find in
> > atlases, too), which STRETCHES areas near the poles (i.e. Greenland
> > isn't nearly as big as most people think). That's why your
> > unprojected
> > data might appear squished by comparison.
> > - Ed
> > Ed McNierney
> > President and Chief Mapmaker
> > TopoZone.com / Maps a la carte, Inc.
> > 73 Princeton Street, Suite 305
> > North Chelmsford, MA 01863
> > Phone: (978) 251-4242 Fax: (978) 251-1396
> > ed at topozone.com
> > Sent: Tuesday, February 18, 2003 11:28 AM
> > To: mapserver-users at lists.gis.umn.edu
> > projection correct
> > David,
> > Thanks for your suggestion. I tried it but it's not quite what I'm
> > looking
> > for. I want horizontal lines of latitude, as I have now. I'd just
> > rather
> > have the vertical less squished.
> > All,
> > I've attached a map displaying identical data in MapInfo and
> > MapServer,
> > with
> > both applications' projection set to latlong. In comparison you can
> > clearly
> > see that the MapServer output is vertically squished.
> > This isn't limited to MapInfo. Nearly any map I can find of a
> > particular
> > area from any source (Mapquest, an atlas, anywhere) is
> similar to the
> > MapInfo view, and the MapServer view looks "squished", for lack of a
> > better
> > term.
> > I've attached a map file below.
> > I appreciate the help guys,
> > Dan Martin
> > # Start of map file
> > NAME NorthAmerica
> > STATUS ON
> > SIZE 800 600
> > UNITS dd
> > IMAGECOLOR 255 255 255
> > FONTSET "..\fonts\fontset.txt"
> > SYMBOLSET "..\symbols\symbolSet.txt"
> > IMAGETYPE PNG
> > # Projection definition, consult the PROJ.4 documentation for
> > parameter
> > discussion
> > PROJECTION
> > proj=latlong
> > END
> > # Start of web interface definition (including WMS enabling
> metadata)
> > WEB
> > TEMPLATE ../Clients/rosaClient.html
> > MINSCALE 1000
> > IMAGEPATH "\inetpub\wwwroot\temp\"
> > IMAGEURL "/temp/"
> > HEADER "../queryTemplates/query_head.html"
> > FOOTER "../queryTemplates/query_foot.html"
> > EMPTY "../MapServer/noRecords.html"
> > END
> > QUERYMAP
> > SIZE 200 200
> > STATUS ON
> > STYLE HILITE
> > COLOR 255 255 0
> > END
> > # Start of reference map
> > REFERENCE
> > IMAGE ../referenceImages/us-reference.gif
> > EXTENT -124.986016 24.403641 -66.490832 68.268767
> > SIZE 160 120
> > STATUS ON
> > COLOR -1 -1 -1
> > OUTLINECOLOR 255 0 0
> > END
> > # LEGEND object
> > LEGEND
> > STATUS off
> > KEYSIZE 40 16
> > OUTLINECOLOR -1 -1 -1
> > TEMPLATE "../legendTemplates/checkBox_legend.html"
> > END
> > # Start of scalebar
> > SCALEBAR
> > IMAGECOLOR 0 125 90
> > BACKGROUNDCOLOR 150 230 150
> > OUTLINECOLOR 255 255 255
> > LABEL
> > COLOR 255 255 255
> > SIZE large
> > END
> > STYLE 0
> > SIZE 200 10
> > COLOR 255 255 255
> > UNITS miles
> > INTERVALS 3
> > TRANSPARENT TRUE
> > STATUS TRUE
> > END
> > # Start of layer definitions
> > LAYER
> > NAME "USA"
> > PROJECTION
> > "proj=latlong"
> > END
> > CONNECTIONTYPE OGR
> > CONNECTION "\GISData\Namerca\USA\Usa_Maps\USA.TAB"
> > STATUS DEFAULT
> > TYPE POLYGON
> > CLASS
> > COLOR 225 225 185
> > END
> > END
> > LAYER
> > NAME "Canada"
> > PROJECTION
> > "proj=latlong"
> > END
> > CONNECTIONTYPE OGR
> > CONNECTION "\GISData\Namerca\Canada\Canada.TAB"
> > STATUS DEFAULT
> > TYPE POLYGON
> > CLASS
> > COLOR 225 225 185
> > END
> > END
> > END
> > > Sent: Tuesday, February 18, 2003 9:59 AM
> > > projection correct
> > > Daniel -
> > > Unfortunately <g>, the map looks just fine. What were you
> > expecting?
> > > Do you have a sample of what a "geographic" projection of
> > > that area does
> > > look like? Canada's going to get stretched quite a bit that way.
> > > - Ed
> > > Ed McNierney
> > > ed at topozone.com
> > > Sent: Tuesday, February 18, 2003 10:51 AM
> > > Subject: [Mapserver-users] Can't seem to get the
> projection correct
> > > I've been playing with my projections for some time now, with no
> > > success.
> > > I'm using entirely OGR data (MapInfo data to be exact). All
> > > the data is
> > > in
> > > latlong. No matter what I try, I end up with maps that are
> > vertically
> > > challenged (squished). See the attachment.
> > > I'd appreciate any advice you can offer.
> > > Thanks,
> > > Daniel Martin
