[Mapserver-users] Can't seem to get the projection correct
Martin, Daniel
DMartin at erac.com
Tue Feb 18 12:26:33 EST 2003
Daniel,
Sorry to correct you, but that's not true - at least not since I've worked
with MapInfo (version 5 through 7). That may be an optional configuration,
but by default MapInfo doesn't change the aspect ratio of the data with the
window. By default, the data's horizontal extent stays the same as the
window is resized, but the vertical changes to maintain the projection.
-Dan
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Tuesday, February 18, 2003 11:20 AM
> To: Martin, Daniel
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Can't seem to get the
> projection correct
> "Martin, Daniel" wrote:
> > Well, perhaps MapInfo is lying to me, but it says the
> projection I am after
> > *is* latlong. It says: "Latitude/Longitude (NAD 27 for
> the Continental
> > US)"
> If I remember well, in MapInfo, when you resize your map window, the
> geographical extents are not changed, but instead the data is
> stretched
> to fit in the new width/height aspect ratio of the view
> window...so you
> can get any kind of vertical stretch or horizontal stretch in MapInfo
> just by resizing the map window. OTOH, MapServer will adjust the
> geographical extent to produce square pixels, so as you
> change your view
> width and height the map always looks the same.
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
