[Mapserver-users] No help from developers regarding configur
e/compile issues?
Madere, Colin
colin.madere at ieminc.com
Tue Feb 18 17:23:25 EST 2003
Understood about the developers having many emails and responses and such.
I did again search the archive but got no results, I'm sure if I picked the
right search terms it would come up, but I've apparently been using list
archives that have friendlier search engines :)
The --enable-internal-ld-detect worked, glad to hear it's being made
default! :)
Off to try the .so and make sure it works. Thanks for the response, Daniel.
> -----Original Message-----
> From: Daniel Morissette [SMTP:morissette at dmsolutions.ca]
> Sent: Tuesday, February 18, 2003 4:00 PM
> To: Madere, Colin
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] No help from developers regarding
> configure/compile issues?
> "Madere, Colin" wrote:
> > Are there no developers reading this list?
> > I'm asking since I brought up (what would seem to me) a serious
> 'configure'
> > issue regarding compiling in support for MapScript many days ago and
> have
> > received zero response.
> The developers are listening, but since we all receive hundreds of
> emails per day related to MapServer and other projects we may not be
> able to answer every question (but we sure wish we could make sure every
> single question is addressed). BTW I've seen that you answered a few
> compilation questions yourself in the last few days and that's great,
> thanks! :)
> > I get the following error when running make:
> > make[1]: Entering directory
> `/spool/build/mapserver-3.6.4/mapscript/php3'
> > cc -xO3 -xdepend -I. -I.. -KPIC -O2 -Wall -DCOMPILE_DL=1 -DPHP4
> > make[1]: cc: Command not found
> > make[1]: *** [php_mapscript_util.o] Error 127
> > make[1]: Leaving directory `/spool/build/mapserver-3.6.4/mapscript/php3'
> Try adding the following option to your MapServer configure:
> This uses a different method to set the LD command to link
> php_mapscript.so and was an attempt to fix the problems that you ran
> into. This new method was experimental in 3.6 and is the default in 3.7
> I hope that helps
> Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
