[Mapserver-users] MAPXY and QUERYITEM
Patrick Rouse
patrickrouse at earthlink.net
Wed Feb 19 21:22:16 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_000A_01C2D85C.FA46A5C0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
I'm trying to set up a popup menu that will receive a lat/lon. I would
like to launch the popup with the lat/lon as the center point of the
map. I would like to use the MAPXY cgi parameter but the reference says
it must be used with a query. Is it possible to do this in mapserver.
My other question is about queryitem. I am submitting a query using
queryitem, but I get a message back that says a filter is not present in
my mapfile. I notice on the query samples page on the mapserver web
site that the query samples contain no filters within the map file, so I
was wondering what I am missing. I've searched the list server archives
and found similar questions but didn't seem to see any solutions to this
questions. Just wonder what I may be missing
Thanks
Ps: any sample code/urls using the cgi commands would be greatly
appreciated.
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C2D85C.F9CF79F0">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>I’m trying to set up a popup menu that will =
receive a
lat/<span class=3DSpellE>lon</span>.<span =
style=3D'mso-spacerun:yes'>
</span>I would like to launch the popup with the lat/<span =
as the center point of the map.<span style=3D'mso-spacerun:yes'> =
</span>I
would like to use the MAPXY <span class=3DSpellE>cgi</span> parameter =
but the
reference says it must be used with a query.<span
style=3D'mso-spacerun:yes'> </span>Is it possible to do this in =
<span
class=3DSpellE>mapserver</span>.<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>My other question is about <span =
class=3DSpellE>queryitem</span>.<span
style=3D'mso-spacerun:yes'> </span>I am submitting a query using =
<span
class=3DSpellE>queryitem</span>, but I get a message back that says a =
filter is
not present in my <span class=3DSpellE>mapfile</span>.<span
style=3D'mso-spacerun:yes'> </span>I notice on the query samples =
page on
the <span class=3DSpellE>mapserver</span> web site that the query =
samples contain
no filters within the map file, so I was wondering what I am =
missing.<span
style=3D'mso-spacerun:yes'> </span>I’ve searched the list =
server
archives and found similar questions but didn’t seem to see any =
solutions
to this questions.<span style=3D'mso-spacerun:yes'> </span>Just =
wonder what
I may be missing<o:p></o:p></span></font></p>
font-family:Arial'>Thanks<o:p></o:p></span></font></p>
font-family:Arial'>Ps: any sample code/<span class=3DSpellE>urls</span> =
using the
<span class=3DSpellE>cgi</span> commands would be greatly =
appreciated.<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_000A_01C2D85C.FA46A5C0--
