[Mapserver-users] converting to perl
Ed McNierney
ed at topozone.com
Tue Feb 25 11:17:40 EST 2003
OK - if you can explain a bit about what you're trying to do, we'll try to help.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Tuesday, February 25, 2003 11:21 AM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] converting to perl
I am trying to use Perl to generate input for mapserver
On Tuesday 25 February 2003 11:09, you wrote:
> Jon -
> I'm not quite sure what your question is. Are you trying to get MapServer
> to process template files to generate Perl output that then gets processed
> and sent to the client? Or are you trying to use Perl to generate input
> for MapServer?
> - Ed
> Ed McNierney
> ed at topozone.com
> (978) 251-4242
> From: Jon Shorie [mailto:jshorie at medinaco.org]
> Sent: Tuesday, February 25, 2003 10:50 AM
> Subject: [Mapserver-users] converting to perl
> I am in the process of trying to convert a mapserver application to perl
> from raw html. Here is a portion of my mcse.map file.
> WEB
> HEADER mcse_header.html
> TEMPLATE mcse.html
> FOOTER mcse_footer.html
> MINSCALE 1000
> MAXSCALE 1550000
> IMAGEPATH "set in mcse_init.html"
> IMAGEURL "set in mcse_init.html"
> METADATA
> WMS_TITLE "MCSE GIS Application"
> WMS_ABSTRACT "This is the Demo of a GIS System for MCSE. It is based
> on the mapserver demo application."
> WMS_ACCESSCONSTRAINTS none
> # change this value to match your setup
> WMS_ONLINERESOURCE "http://172.16.40.17/cgi-bin/mcsegis/mcse_init.cgi"
> WMS_SRS "EPSG:26915"
> END
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
