[Mapserver-users] converting to perl
Jon Shorie
jshorie at medinaco.org
Tue Feb 25 12:55:45 EST 2003
I will be more specific. I currently have a mapserver application up on a
local network. My eventual goal is to integrate mapserver into some of our
backend database processing applications. Initially I am just looking to be
able to run some perl code of a user of the mapserver queries on a layer.
What I would like to do is to use the layer information to issue a query to a
backend database which would pull up service information for hydrants if the
user clicks on the hydrant.
The way that I am handling this currently is to have an html page called by
the query on the layer like so:
<tr><td>[ID]</td><td>[NUMBER]</td><td>[NEWFIELD1]</td>
<td>[NAME]</td><td>Click <a
href=http://172.16.40.17/cgi-bin/publichydrants/resultshydrant.cgi?sort=none&hydrantname=[NAME]>
Here</a> for data on this hydrant<td></tr>
Here is the reference in the mcse.map file.
LAYER
NAME hydrants
TYPE POINT
MAXSCALE 300000
STATUS DEFAULT
DATA hydrants
CLASS
NAME "Hydrants"
TEMPLATE "hydrants.html"
COLOR 255 0 0
SYMBOL 'circle'
SIZE 7
END
What this method does is if the user queries a hydrants feature they get a
page that says clieck here for data on this hydrant. If the user then clicks
on the link sends the hydrantname to a perl script that queries the database.
What I would prefer to do is to have the query to directly to the perl script
and not even bring up the intermediate page.
Is this possible?
On Tuesday 25 February 2003 11:17, you wrote:
> OK - if you can explain a bit about what you're trying to do, we'll try to
> help.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: Jon Shorie [mailto:jshorie at medinaco.org]
> Sent: Tuesday, February 25, 2003 11:21 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] converting to perl
> I am trying to use Perl to generate input for mapserver
> On Tuesday 25 February 2003 11:09, you wrote:
> > Jon -
> > I'm not quite sure what your question is. Are you trying to get
> > MapServer to process template files to generate Perl output that then
> > gets processed and sent to the client? Or are you trying to use Perl to
> > generate input for MapServer?
> > - Ed
> > Ed McNierney
> > ed at topozone.com
> > (978) 251-4242
> > Sent: Tuesday, February 25, 2003 10:50 AM
> > Subject: [Mapserver-users] converting to perl
> > I am in the process of trying to convert a mapserver application to perl
> > from raw html. Here is a portion of my mcse.map file.
> > WEB
> > HEADER mcse_header.html
> > TEMPLATE mcse.html
> > FOOTER mcse_footer.html
> > MINSCALE 1000
> > MAXSCALE 1550000
> > IMAGEPATH "set in mcse_init.html"
> > IMAGEURL "set in mcse_init.html"
> > METADATA
> > WMS_TITLE "MCSE GIS Application"
> > WMS_ABSTRACT "This is the Demo of a GIS System for MCSE. It is based
> > on the mapserver demo application."
> > WMS_ACCESSCONSTRAINTS none
> > # change this value to match your setup
> > WMS_ONLINERESOURCE
> > "http://172.16.40.17/cgi-bin/mcsegis/mcse_init.cgi"
> > WMS_SRS "EPSG:26915"
> > END
> > END
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
