[Mapserver-users] Compile Problems 3.6.4, nightly with Solari
s8
Madere, Colin
colin.madere at ieminc.com
Tue Feb 25 12:01:40 EST 2003
NP, I found that STATIC_LIBS thing from another project which got the same
error. I'm wondering if using the GNU compiler AND linker would change
things (since I'm using the Sun linker).
FYI, I don't get the error you list and I have:
Solaris 8 on SPARC
mapserv 3.6.4 (release, not nightly)
gcc 3.2 (3.2.0?)
bison 1.875
flex 2.5.4
> -----Original Message-----
> From: Oliver Wesp [SMTP:wesp at gdv.com]
> Sent: Tuesday, February 25, 2003 3:38 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Compile Problems 3.6.4, nightly with
> Solaris8
> Hi,
> meanwhile I found a solution and maybe this is usefull for anybody running
> into this. Bison 1.875 was causing this error. I stepped back to usig
> bison
> 1.28 and it went away.
> My latest environment was Solaris8, gcc 3.2.2, bison 1.28, flex 2.5.4 and
> the compilation was succesfull.
> greetings
> Oliver
> P.S. Thanks to Coline Madere for the STATIC_LIBS hint.
> At 17:40 17.02.2003 +0100, Oliver Wesp wrote:
> >Dear List,
> >I'm trying to compile the latest nightly.tar from the website. Anybody
> >came across the following error:
> >bison -y -p msyy -d -p -omapparser.c mapparser.y
> >***Signal 13
> >make: Fatal error: Command failed for target 'mapparser.c'
> >I guess I'm making some stupid mistake cause 3.6.4 gives me the same
> >error. With 3.6.3 ereything works fine. I'm using Solaris8, gcc 2.95.3,
> >bison 1.875 .
> >Any hint is appreciated.
> >kind regards
> >Oliver
> >_______________________________________________
> >Mapserver-users mailing list
> >Mapserver-users at lists.gis.umn.edu
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Dipl.-Geogr. Oliver Wesp
> Gesellschaft für geografische Datenverarbeitung
> Binger Strasse 49-51
> D-55218 Ingelheim
> fon: +49 6132 714818
> fax: +49 6132 714828
> http: <http://www.gdv.com>www.gdv.com
