[Mapserver-users] Compile Problems 3.6.4, nightly with
Solaris8
Oliver Wesp
wesp at gdv.com
Tue Feb 25 04:37:40 EST 2003
meanwhile I found a solution and maybe this is usefull for anybody running
into this. Bison 1.875 was causing this error. I stepped back to usig bison
1.28 and it went away.
My latest environment was Solaris8, gcc 3.2.2, bison 1.28, flex 2.5.4 and
the compilation was succesfull.
greetings
Oliver
P.S. Thanks to Coline Madere for the STATIC_LIBS hint.
At 17:40 17.02.2003 +0100, Oliver Wesp wrote:
>Dear List,
>I'm trying to compile the latest nightly.tar from the website. Anybody
>came across the following error:
>bison -y -p msyy -d -p -omapparser.c mapparser.y
>***Signal 13
>make: Fatal error: Command failed for target 'mapparser.c'
>I guess I'm making some stupid mistake cause 3.6.4 gives me the same
>error. With 3.6.3 ereything works fine. I'm using Solaris8, gcc 2.95.3,
>bison 1.875 .
>Any hint is appreciated.
>kind regards
>Oliver
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dipl.-Geogr. Oliver Wesp
Gesellschaft für geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: <http://www.gdv.com>www.gdv.com
