[Mapserver-users] PERL mapscript polygon shapefile creation
Eric Bridger
eric at gomoos.org
Tue Feb 25 12:12:55 EST 2003
--=-tXobYR1b8yN9iCuMfdz5
Content-Type: text/plain
Content-Transfer-Encoding: 7bit
Joe,
Turns out I just wrote such a script today. The only problem I see
with your script is that I think you should call $shape->setBounds()
after you've added all your lines and before $shapeFile->add($shape).
I've attached my script. It reads a list of polygon centroids in
decimal degrees and creates 10 minute squares.
Eric
On Tue, 2003-02-25 at 19:41, Joe Bussell wrote:
> Greetings Listers,
> I am having difficulty porting a technique we use to create point
> and line type shapefiles to create a polygon shapefile. Has anyone used
> PERL to create polygon shapefiles from data files? I have attached my
> attempt for review. The script creates a shapefile that is readable by
> dump.pl, but I have not been able to use it in a map render.
> I tried this with a data file with the following lines:
> 40.0 -116.0
> 45.0 -116.0
> 45.0 -120.0
> 40.0 -120.0
> The script "closes" the polygon by inserting the first record at the end.
> Any ideas?
> Cordially,
> Joe Bussell
Content-Disposition: attachment; filename=nmfs2shp.pl
Content-Transfer-Encoding: quoted-printable
Content-Type: text/x-perl; name=nmfs2shp.pl; charset=ISO-8859-15
#!/usr/bin/perl -w
use strict;
use mapscript;
use XBase;
# NNFS INPUT comma separated centroids.
#0 NFNS 10 minute square id
#1 Total catch pounds
#2 Centroid Latitude (decimal degrees)
#3 Centroid Longitude (decimal degrees)
my $file =3D shift or die "No input file\n";
my $shapeFile =3D new mapscript::shapefileObj("nmfs_squares", $mapscript::M=
S_SHAPEFILE_POLYGON);
my $dbf_file =3D XBase->create(
"name" =3D> "nmfs_squares.dbf",
"field_names" =3D> ["NMFSID", "TOTAL_CATCH"],
"field_types" =3D> ["C", "N"],
"field_lengths" =3D> [7, 6],
"field_decimals" =3D> [undef, 0]);
my $count =3D 0;
open(IN, $file) or die "Could not open $file\n";
while(my $line =3D <IN>){
chomp $line;
$line =3D~ s/"//g;
my @flds =3D split(/,/, $line);
my $shape =3D create_rect($flds[2], $flds[3]);
if(!$shape){
warn "No shape\n";=09
next;
$shapeFile->add($shape);
$dbf_file->set_record($count, $flds[0], $flds[1]);
$count++;
close (IN);
undef $shapeFile;
$dbf_file->close();
print "Created: $count\n";
exit;
sub create_rect{
my($lat, $lon) =3D @_;=09
my $point =3D new mapscript::pointObj();
my $line =3D new mapscript::lineObj();
# max xy point
$point->{x} =3D $lon + .0833;
$point->{y} =3D $lat + .0833;
$line->add($point);
# max x min y
$point->{y} =3D $lat - .0833;
$line->add($point);
# min xy
$point->{x} =3D $lon - .0833;
$line->add($point);
# min x max y
$line->add($point);
# max xy point again to close polygon
$line->add($point);
my $shp =3D new mapscript::shapeObj($mapscript::MS_SHAPE_POLYGON);
$shp->add($line);
$shp->setBounds();
return $shp;
--=-tXobYR1b8yN9iCuMfdz5--
