[Mapserver-users] PERL mapscript polygon shapefile creation
Joe Bussell
joe at otsys.com
Tue Feb 25 14:41:56 EST 2003
This is a multi-part message in MIME format.
--------------020907060906090201030909
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Greetings Listers,
I am having difficulty porting a technique we use to create point
and line type shapefiles to create a polygon shapefile. Has anyone used
PERL to create polygon shapefiles from data files? I have attached my
attempt for review. The script creates a shapefile that is readable by
dump.pl, but I have not been able to use it in a map render.
I tried this with a data file with the following lines:
40.0 -116.0
45.0 -116.0
45.0 -120.0
40.0 -120.0
The script "closes" the polygon by inserting the first record at the end.
Any ideas?
Cordially,
Joe Bussell
Content-Type: application/x-perl;
name="getNavZone.pl"
Content-Disposition: inline;
filename="getNavZone.pl"
#!/usr/bin/perl -w
use strict;
use Carp;
use Getopt::Std qw(getopts);
use File::Copy qw(copy move);
use Date::Manip;
use mapscript;
use XBase;
use vars qw{ $v $shapeFile $dbfTable };
my $lineNumber = 0;
#get command line parameters
my %args = ();
getopts("I:O:vs", \%args);
$v = ( defined $args{v} );
if ( $v )
print "Build shapefile with one polygon from a text file.\n";
if ( !defined $args{I} || !defined $args{O} )
croak "getNavZone.pl [-v] -I inputFileName -O outputFileNameBase\n"
." extracts lines with enough geocoding information into a shapefile and an associated DBF.\n"
my $inputFileName = $args{I};
my $outputFileNameBase = $args{O};
if ( $args{v} )
print "Input file = $inputFileName\n";
print "Output shapefile = $outputFileNameBase.shp\n";
print "Output dbf file = $outputFileNameBase.dbf\n";
open( IN_FILE, "< $inputFileName" ) or croak "Cannot open $inputFileName $!\n";
my $shapeFileName = $outputFileNameBase . ".shp";
my $dbfFileName = $outputFileNameBase . ".dbf";
my $idxFileName = $outputFileNameBase . ".shx";
my $tempShapeFileName = "./temp.shp";
my $tempDbfFileName = "./temp.dbf";
my $tempIdxFileName = "./temp.shx";
unlink $tempShapeFileName or carp "Could not delete $tempShapeFileName $!\n";
unlink $tempDbfFileName or carp "Could not delete $tempDbfFileName $!\n";
unlink $tempIdxFileName or carp "Could not delete $tempIdxFileName $!\n";
$shapeFile = new shapefileObj( $tempShapeFileName, $mapscript::MS_SHAPEFILE_POLYGON )
or croak "Cannot open $tempShapeFileName $!\n";
$dbfTable = XBase->create( "name" => $tempDbfFileName,
"field_names" => [ "ID" ],
"field_types" => [ "N" ],
"field_lengths" => [ 10 ],
"field_decimals" => [ 0 ] ) or croak "Cannot create dbfTable $!\n";
sub createPolygon
my $latRef = shift;
my $lonRef = shift;
my $id = shift;
my $shape = new shapeObj($mapscript::MS_SHAPE_POLYGON);
my @latRA = @$latRef;
my @lonRA = @$lonRef;
my $len = @latRA;
for( my $i = 0; $i < $len; $i++ )
my $lat = $latRA[ $i ];
my $lon = $lonRA[ $i ];
my $point = new pointObj();
my $line = new lineObj();
$point->{x} = $lon;
$point->{y} = $lat;
$line->add( $point );
$shape->add( $line );
$lineNumber++;
$shapeFile->add( $shape );
$dbfTable->set_record( $id, $id );
print "Should have made a point in the polygon shapefile = $id $lineNumber\n";
sub trim
my @out = @_;
for ( @out )
s/^\s+//;
s/\s+$//;
return wantarray ? @out : $out[0];
my $num = 0;
my $numSuccesses = 0;
my $numFailures = 0;
my $center = "";
my @lats;
my @lons;
my $id = 0;
my $firstLat = 0;
my $firstLon = 0;
while ( <IN_FILE> )
chop;
my $line = &trim( $_ );
if ( /^\s*$/ )
carp "$num: No data\n" if ( $v );
++$num;
next;
elsif ( /^(\S+)\s+(\S+)$/ )
push( @lats, $1 );
push( @lons, $2 );
carp( "$1, $2\n" );
if ( $num == 0 )
$firstLat = $1;
$firstLon = $2;
else
carp "ERROR $num $line\n";
++$num;
next;
++$num;
push( @lats, $firstLat );
push( @lons, $firstLon );
&createPolygon( \@lats, \@lons, $id );
undef $shapeFile;
undef $dbfTable;
if ( !copy( $tempShapeFileName, $shapeFileName ) )
carp "Can't cp $tempShapeFileName $shapeFileName\n";
if ( !copy( $tempDbfFileName, $dbfFileName ) )
carp "Can't cp $tempDbfFileName $dbfFileName\n";
if ( !copy( $tempIdxFileName, $idxFileName ) )
carp "Can't cp $tempIdxFileName $idxFileName\n";
`/usr/bin/shptree $shapeFileName`;
close IN_FILE;
1;
exit;
--------------020907060906090201030909--
