[Mapserver-users] preprocessing 24bit Rasterdata
Vincent Schut
schut at sarvision.com
Wed Jul 9 04:48:23 EDT 2003
You could try imagemagick (www.imagemagick.org), an image processing lib/suite
that comes with several very powerfull command line (batch processing) tools.
I don't remember the command to create a palette image from a rgb, but I know
I once did it with imagemagick and it worked well.
Cheers,
Vincent.
On Wednesday 09 July 2003 10:17, Christina Biakowski \(CCGIS\) wrote:
> Hello,
> since I am still using Mapserver 3.6, I have to convert my rasterdata
> (24bit orthophotos, TIFF) into 8bit.
> Does any of the GDAL-utilities supply this convert-function? I am not very
> familiar with image-formats and properties and searching the gdal-site and
> the mailing-archive did not help to answer my question.
> Or which other tool I could use alternatively to convert my images? (in a
> batch-process, because I have quite a lot images to convert. The image
> processing program I am using does not support the conversion in a batch.)
> Thanks a lot!
> Regards,
> Christina
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
