[Mapserver-users] the performance in linux against win2k?
=?gb2312?q?Chen=20Fu?=
novalet at yahoo.com.cn
Sat Jun 14 08:29:34 EDT 2003
ahh, I have never notice the mode=map yet. i test it,
and find the mapserv with "mode=map" will only return
image itself not the template html. It is definitely
useful if i use mapserver in a virtual host site
(maybe impossible to have a winnt task to remove temp
file everyday).
But my experience of mapserver is rather limited. Do
you know how to use mode=map and template html
together? Any demo already?
Thank you in advance!
--- Ed McNierney <ed at topozone.com> µÄÕýÎÄ£º> Chen -
> We run on Windows and Linux on different hardware
> and are happy with both.
> You should realize that the time involved in
> creating/launching a process is a pretty
> insignificant one given the work MapServer has to
> do. For a given request you launch the process,
> load the MAP file, parse it, open and load
> potentially many map layers from SHP files, TIFF
> images, etc., then generate output images and send
> the data to the client. The process creation time
> simply does not matter.
> I mentioned at the user meeting that some folks
> don't know that when the CGI is run in "mode=map"
> (or "legend" or "scalebar") that the server will
> write the generated image directly back to the
> client browser. In "mode=browse" the generated HTML
> is written back after the map image is written to
> the server's local disk in the TMP directory. If
> you can avoid writing an image to disk for every map
> request, you will boost your performance far more
> than any improvement you'll get from optimizing
> process creation time.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> Phone: (978) 251-4242 Fax: (978) 251-1396
> ed at topozone.com
> -----Original Message-----
> From: Chen Fu [mailto:novalet at yahoo.com.cn]
> Sent: Thursday, June 12, 2003 10:17 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] the performance in linux
> against win2k?
> Hi!
> I recently use mapserver as cgi with win2k+appache.
> It
> works nice.
> But i read from some articles that creating process
> in
> win2k+appache is relatively slow than linux, so cgi
> is
> not a good solution in win2k. Is it right?
> Will it benefit a lot if i setup a linux in the same
> pc to replace win2k?
> Remote Scensing Satellite Ground Station
> Chinese Academy of Science
_________________________________________________________
> Do You Yahoo!?
> Á÷Á¬ÍøÂçÊÀ½çµÄ¡°Ä㡱ÊÇË£¿
http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/cn_user_profile_study_may2003
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Do You Yahoo!?
