[Mapserver-users] mapserv doesn't work
Vincent Schut
schut at sarvision.com
Fri Jun 20 04:17:58 EDT 2003
Chen,
The error you get is a very generic error generated by php I think. To find
out more about what goes wrong, you should at least run mapserver from the
command prompt, and prefereable thourgh a debugger.
To run it from the command prompt, type (in the dir where the mapserv
executable is):
./mapserv "QUERY_STRING=map=/var/mapserver/mapfiles/province2.map&mode=map"
(of course fill in your own mapfile/path and eventual other parameters. I
think you need to specify at least map and mode. This example prints the
image data to stdout, so you will see your png or gif or whatever scrolling
as ascii on you terminal :-)
But probably you will see an error message instead of image data.
If it is still very generic, like a segmentation fault, you should use a
debugger.
To run mapserv from the debugger, do the following:
make sure you have gdb (the gnu debugger) and type:
gdb mapserv
run "QUERY_STRING=map=/var/mapserver/mapfiles/province2.map&mode=map"
and after the error, type:
backtrace
This will show you in which function mapserv (or a library) segfaulted.
Maybe than you will know what to do. Otherwise, send your experiences and the
mapserv and debugger output to this list and I'm sure you will get more
help.
Cheers,
Vincent Schut.
On Friday 20 June 2003 09:12, Chen Fu wrote:
> Till£º
> My linux box is base on redhat8. the make generate
> some warning but no error. the mapserv is 375445
> bytes. I think it is much smaller than the one i used
> in win2k. But i config it with gd lib only.
> if i type "./mapserv" it will show
> This script can only be used to decode form results
> and
> should be initiated as a CGI process via a httpd
> server.
> Is it mean the file is a validate executable? shp2img
> generated in the same procession work very nice.
> I search the archive for that message before i post it
> here. But most i found is related to php or some other
> thing. Because i am a newbie in compiling mapserver in
> linux, so i select the cleanest way, use only gd lib.
> But still get into trouble, sigh...
> --- Till Adams <adams at terrestris.de> µÄÕýÎÄ£º> Dear
> Cheng,
> > "premature end of script" is an error which occurs,
> > when the compile
> > process was broken up: so while compiling, the
> > "mapserv" was written but
> > not finished. Which linux system do you use? Did you
> > get an error
> > message when compiling? Try the mailing list archive
> > searching for
> > contributions fitting to your error message.
> > Good luck,
> > Till
> > Chen Fu schrieb:
> > > Hi!
> > > This is my first time to compile mapserver in
> > linux.
> > > But I use mapserver in win2k for a long time.
> > > First download gd-2.0.15, make and install it.
> > > Then i download mapserver4.0b, make it and copy
> > > mapserv to cgi-bin.
> > > But when i input http://localhost/cgi-bin/mapserv
> > > the info in the brower is
> > > Server error!
> > > The server encountered an internal error and was
> > > unable to complete your request.
> > > Error message:
> > > Premature end of script headers: mapserv
> > > I have tried shp2img, it work fine, and generate
> > > proper image.
> > > Can you give me some suggestion?
> > > Remote Scensing Satellite Ground Station
> > > Chinese Academy of Science
> _________________________________________________________
> > > Do You Yahoo!?
> > > ÍøÁµµÄÚ¹ÊÍ£ºÕæÇ黹ÊÇ·Å×Ý£¿
> http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/netlove
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > ***** Treffen Sie uns auf der AGIT in Salzburg vom
> > 2. bis 4. Juli 2003,
> > Stand 35 *****
> > Dipl. Geogr. Till Adams
> > terrestris, Paulsen&Adams GbR
> > Siemensstr. 8 * 53121 Bonn
> > Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
> > info at terrestris.de * www.terrestris.de
> Do You Yahoo!?
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
