[Mapserver-users] building Mapserver 3.6.5 on Mac OS X 10.2.5
John Oram
mapserver at oram.com
Fri May 9 20:56:03 EDT 2003
Due to vigilant web-based research, I just figured out that the
shapelib is included in the gdal distribution.
Aaron, I'm not sure what errors you're seeing, but I stumbled across
this reference in the archives:
http://mapserver.gis.umn.edu/cgi-bin/wilma_hiliter/mapserver-users/
0301/msg00112.html?line=59#hilite
So if I read this correctly, if you do "make install" in the gdal
directory, you can just use "--with-gdal" in the Mapserver
./configure, unless it's not in your path, in which case you'd have to
tell it
"--with-gdal=/usr/local/lib"
If you don't do "make install" then you have to point it at
"--with-gdal=../gdal-1.1.7/apps/gdal-config"
Looks like I'm going the latter route as I got an error when I tried
"make" on gdal.
-John
On Friday, May 9, 2003, at 12:19 PM, Aaron D. Hunt wrote:
> I did have gdal-1.1.7 and I just installed gdal-1.1.8. How can I clean
> out
> the old one if this is the problem?
> Thanks
> Aaron
> ----- Original Message -----
> From: "John Oram" <mapserver at oram.com>
> To: "Daniel Morissette" <morissette at dmsolutions.ca>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, May 09, 2003 2:33 PM
> Subject: Re: [Mapserver-users] building Mapserver 3.6.5 on Mac OS X
> 10.2.5
>> Daniel et al-
>> Yup, looks like my original download of the tar.gz got truncated, or
>> didn't ungzip or untar properly. Redownloaded via cURL and
>> mapscript/php3 is there. Thanks for the tip.
>> As for my latest entertaining error (boy, this sure is a good way to
>> learn about the intricacies of software build :) when I make
>> Mapserver,
>> I get this error:
>> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>> -DUSE_PROJ_API_H -DUSE_WMS -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG
>> -DUSE_GD_WBMP -DUSE_GD_FT
>> -I/usr/local/src/mapserver-3.6.5/../gd-1.8.4 shp2img.c -o
>> shp2img.o
>> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>> -I/usr/local/src/mapserver-3.6.5/../gd-1.8.4 shp2img.o
>> -L. -lmap -L/usr/local/src/mapserver-3.6.5/../gd-1.8.4 -lgd -ljpeg
>> -L/usr/local/lib -lpng -lz -ljpeg -L/usr/local/lib -lpng -lz -lproj
>> -ljpeg -lm -o shp2img
>> ld: Undefined symbols:
>> ___gxx_personality_v0
>> make: *** [shp2img] Error 1
>> I searched the archives and found the suggestion by Norman Vine to add
>> "--with-xpm=no" but this didn't help matters. (I used ./configure
>> --with-jpeg --with-gd=../gd-1.8.4 --with-proj
>> --with-zlib=/usr/local/lib --with-png=/usr/local/lib
>> --with-php=/usr/local/src/php-4.3.1 --with-xpm=no)
>> This may or may not be related to another question I have -- I saw a
>> reference to shapelib-1.2.10 -- I downloaded it and have it in my
>> /usr/local/src. I didn't see any mention of it in any of the install
>> instructions I've seen (for any OS) and wasn't able to tell if this
>> was
>> bonus material or required to import shapefiles. Could this be
>> causing
>> the shp2img error I'm seeing?
>> Confusedly yours,
>> John
>> On Thursday, May 8, 2003, at 04:55 PM, Daniel Morissette wrote:
>>> John Oram wrote:
>>>> updating cache ./config.cache
>>>> creating ./config.status
>>>> creating Makefile
>>>> mkdir: mapscript/php3: No such file or directory
>>>> creating mapscript/php3/Makefile
>>>> sed: ./mapscript/php3/Makefile.in: No such file or directory
>>> Seems like you are missing some files in the source code distribution
>>> that you got, or the directory structure got lost for some reason.
>>> You should have a subdirectory called mapscript/php3, and it should
>>> contain a file called mapscript/php3/Makefile.in, plus other source
>>> files, etc.
>>> Daniel Morissette morissette at dmsolutions.ca
>>> DM Solutions Group http://www.dmsolutions.ca/
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
