[Mapserver-users] data/mapfile organization advice sought
Puneet Kishor
pkishor at geoanalytics.com
Tue May 13 00:08:47 EDT 2003
To ms data mavens -- please give me a piece of your mind.
I have shapefile data of several countries, about 14 countries.
Each country has 8 to 12 different layers, but they are all called the
same. For example, all countries have a layer called "layer1",
"layer2", and so on, while a few countries may not have "layer8" or
"layer11," etc.
If I were to draw all the countries together, they would draw
correctly, that is, they are in the correct geographic space. However,
their data are self-contained. That is, even though country1 and
country2 are contiguous, drawing country1 does not bring up country2...
they are in different folders.
How do I create and work with their mapfiles?
I can't really have one big mongo mapfile with all the layers of all
the countries... it would be unworkable, and probably very inefficient.
On the other hand, if I have 14 different mapfiles, they will be almost
identical to each other except for the path to the data. If I make a
tweak in any one mapfile (for example, change the color or visible
scale of a layer), I will have to go and change it in 14 different
mapfiles.
Ideally I would like to have one master mapfile (like a template), and
just substitute (on the fly) the path to the data. I guess I could do
some preprocessing with Perl, and swap a filter keyword using regexp
search, to create a working, valid mapfile on the fly, but I would also
have to account for those one or two particular layers that happen to
be absent for a given country.
Please share your insight.
Many tia.
Puneet.
