[Mapserver-users] Re: python mapscript 3.7/4.0
Michael Schulz
mschulz at webgis.de
Mon May 26 03:29:27 EDT 2003
Hi Sean,
yes, i tried building it from scratch with a mapserver nightly of last
friday. Could it also be related to any system stuff?
Michael
Sean Gillies schrieb:
> Michael,
> The newer code in pymodule.i uses a new-ish function in maperror.c
> named msResetErrorList. Did you remember to make clean and re-make
> your mapserver source before rebuilding mapscript?
> cheers,
> Sean
> On Saturday, May 24, 2003, at 11:06 AM, Michael Schulz wrote:
> > Hi,
> > i keep having problem with the python mapscript build with some newer
> > version of pymodule.i (v.1.2). The python setup_wnone.py build command
> > stops with:
> > "error: command 'gcc' failed with exit status 1"
> > If i use an older version of pymodule (1.1) the build process gives no
> > errors and python/mapscript is built and working properly. What could
> > be the problem?
> > Cheers, Michael
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
