[Mapserver-users] flash output problem
William A. Bronsema, C.E.T.
bronsema at dmsolutions.ca
Fri Nov 7 13:23:22 EST 2003
For the record...
-------- Original Message --------
Subject: RE : flash output problems
Date: Fri, 7 Nov 2003 18:17:14 +0100
To: <bronsema at dmsolutions.ca>
Thank you!
This time it's ok! great.
The problem was that, when outputting swf, mapserver tryed to output the
scalebar in swf too.
So It ran, ran, ran and never stopped.
I resolve with using a $gpoMap->selectoutputformat("PNG");
just before the $img = $gpoScaleBar->draw();
and this time, that work!
Just a few question more...
It's not possible to use the <INPUT TYPE=image SRC=\"$url to display
the movie, right?
It is mandatory to use <Object....>.... </Object> right?
If I choose Outputformat = multiple, What should I use to display them
together?
Can I do that with php or should I use flash mx to create a projects and
some actionscript code?
Thank you again!
Cheers!
-------- Message d'origine--------
De: William A. Bronsema, C.E.T. [mailto:bronsema at dmsolutions.ca]
Date: ven. 07.11.2003 12:34
Ã: BAUD remi
Cc:
Objet: Re: RE : flash output problems
BAUD remi wrote:
> Hi,
> Thank you for your help, but it still don't work. :-(
Hmmmm....very odd. It works fine for me.
> I took your .map file and I've set the IMAGETYPE PNG to IMAGETYPE SWF.
> I think it was the right thing to do.
It doesn't matter what this is set to if your script sets the output
type at runtime (strongly recommended).
> Results: The swf files are written but php still crashes...
Can you be more specific? Error messages?
> What is your configuration? Did you use the files: ms4w_0.6 with
gmap_ms4w ?
> Because there is two gmap demo application (gmap_ms40 and gmap_ms35)
gmap_ms40 must be used in order to use swf output.
> Did you make changes to php config?
> what is you platform win2k?
> Do I need the shockwave or flash or other plugin?
None of that *should* matter.
> I will try to install ms4w on another pc, perhaps my windows is
"corrupt"..
> Thank you in advance,
> cheers
Below is a simple script to output the swf images. When the script is
done it outputs the swf images to the ms4w ms_tmp folder and echos out
the filename. I ran this script with the exact mapfile I sent to you.
Please run the script (edit accordingly) and let me know if you still
have the same problem.
<?php
// define variables
define( "MAPFILE", "../map/swf.map" );
define( "MODULE", "php_mapscript_40.dll" );
// set the max execution time (seconds)
ini_set("max_execution_time", "60");
// load the mapscript module
if (!extension_loaded("MapScript")) dl(MODULE);
// open map
$oMap = ms_newMapObj( MAPFILE, dirname( MAPFILE ) );
$oMap->selectoutputformat("swf");
// draw map
$oImage = $oMap->draw();
// output map
echo $oImage->saveWebImage("");
Regards,
Bill
Applications Developer,
DM Solutions Group Inc.
http://www.dmsolutions.ca
email: bronsema at dmsolutions.ca
Phone: (613) 565-5056 ext.25
Fax : (613) 565-0925
____________________________________
