[Mapserver-users] Problems with tiff
woodbri at swoodbridge.com
Thu Nov 20 09:04:45 EST 2003
Mapserver expects tiff world files to have the extension *.wld so
rename your *.tfw to *.wld and you should be all set.
-Steve W
On 20 Nov 2003 at 11:40, Stefan Wiegand wrote:
> Hello,
> I am very confused about using mapserver under debian linux. A few weeks
> ago I posted a problem about compiling mapserver with input=tiff. After
> some very hard days I reached this result:
> MapServer version 3.6.6 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> INPUT=TIFF INPUT=EPPL7 INPUT=SHAPEFILE
> TIFF prompts at all errors (make install) but a seperate libtiff 'make'
> was ok.
> (First ./configure in tiff 3.5.7, then ./make in tiff 3.5.7 and then cd
> libtiff and ./make. Mapservers configure --with-tiff=../libtiff)
> But now, the mapserver does not display the tiffs. When I use a single
> TIFF with TFW or an imgtile, the map prompts:
> readWorldFile(): Unable to access file. Unable to open world file for
> reading.
> The tfw and tiff files are in the same directory and there are no
> difference in typing the filenames and I have the same mapservice under
> cygwin running without any problems with the same datas.
> If you have a hint for me (all the same whether large or small ;-)),
> please answer
> Stefan
