[Mapserver-users] WMS and Querymap: Show several layers in querymap
Till Adams
adams at terrestris.de
Thu Nov 20 09:52:33 EST 2003
Dear Daniel,
and to all who don't need more growing grey hair...
thanks - your workaround did it!
We added hard-wired layer names to the query_layers list and the
(hard-wired) layers are drawn in the query-map.
If one of the hard-wired layer does not exist in the mapfile, the
querymap with the other layers is drawn anyway, without any error mesage
-- that's comfortable.
Greetings,
Till ;-)
> Till Adams wrote:
>> we have a problem using querymap through a WMS GetFeature-Info-request.
>> We only get a querymap where the queried layer is displayed, all other
>> layers, which are set to "on" in the map are not displayed in the
>> querymap.
>> We use Info_Mime_type 'text/html'
>> the querymap style is set to "HILITE"
> It's quite likely that the QUERY_LAYERS parameter takes precedence over
> LAYERS value in the WMS GetFeatureInfo request and the non-queryable
> layers end up being turned off. Um... perhaps one thing you could do to
> work around the problem is to pass the same list of layer names in
> QUERY_LAYERS that you pass in LAYERS. The layers that don't have a
> template won't be queried anyway but they will show up in the query map.
> If that doesn't work for you then please file a bug in bugzilla.
> Daniel
