[Mapserver-users] Tutorial raster examples on Mapserver 4.0?
Frank Warmerdam
warmerdam at pobox.com
Tue Sep 2 22:20:39 EDT 2003
Ann Keane wrote:
> I'm trying to run the 3.5 tutorial examples on a 4.0 mapserver to test
> the GDAL installation. I can't get the raster examples to work:
> http://terrasip.gis.umn.edu/projects/tutorial35/s2/s2ex3.html
> mapserv -v
> MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> The example works if I remove the raster layer. I've set DEBUG on and
> tried logging it to a file, but I don't get any errors. Is there any
> other way to test the installation?
Ann,
Things that may be different now:
o The way paths to data files are resolved is different in subtle ways.
Try an absolute path, or relative to SHAPEPATH or relative to the map.
o World file handling may be slightly different. Does gdalinfo report
proper georeferencing for the file in question? Georeferencing that
makes sense relative to the map area?
o Offsite handling is different, you may need OFFSITE r g b to get proper
offsite handling.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
