[Mapserver-users] Tutorial raster examples on Mapserver 4.0?
Ann Keane
Ann.Keane at noaa.gov
Wed Sep 3 18:06:19 EDT 2003
Maybe you can see what I'm missing. I compiled MS3.5 and the original
example works. Under MS4.0, all I get is an empty png image. Here's
what I've got for MS4.0.
The map file for ms4.0 is:
NAME S2EX2
EXTENT -97.5 41.619778 -82.122902 49.38562
SIZE 400 300
SHAPEPATH ""
LAYER # Shaded Relief Raster
NAME "relief"
DATA
"/httpd/www/programs/2003/neaqs/tutorial35/data/raster/shdrlfi020g_ugl.tif"
# STATUS DEFAULT # default does not work
STATUS ON
TYPE RASTER
END
END # end of map file
gdalinfo returns:
Driver: GTiff/GeoTIFF
Size is 2066, 1023
Coordinate System is `'
Origin = (-98.607616,49.868450)
Pixel Size = (0.009075,-0.009075)
Metadata:
TIFFTAG_SOFTWARE=IMAGINE TIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: etif.c $ $Revision: 1.8 $ $Date: 2001/01/25 22:04:51Z $
Corner Coordinates:
Upper Left ( -98.6076164, 49.8684504)
Lower Left ( -98.6076164, 40.5847254)
Upper Right ( -79.8586664, 49.8684504)
Lower Right ( -79.8586664, 40.5847254)
Center ( -89.2331414, 45.2265879)
Band 1 Block=2066x3 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
The world file is:
0.00907499999999999970
0.0
0.0
-0.00907499999999999970
-98.603078920282087
49.863912932356655
I've also tried:
0.009075
0.0
0.0
-0.009075
-98.6076164
49.8684504
Thanks-
Ann
Frank Warmerdam wrote:
> Ann Keane wrote:
>> I'm trying to run the 3.5 tutorial examples on a 4.0 mapserver to test
>> the GDAL installation. I can't get the raster examples to work:
>> http://terrasip.gis.umn.edu/projects/tutorial35/s2/s2ex3.html
>> mapserv -v
>> MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
>> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7
>> INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> The example works if I remove the raster layer. I've set DEBUG on and
>> tried logging it to a file, but I don't get any errors. Is there any
>> other way to test the installation?
> Ann,
> Things that may be different now:
> o The way paths to data files are resolved is different in subtle ways.
> Try an absolute path, or relative to SHAPEPATH or relative to the map.
> o World file handling may be slightly different. Does gdalinfo report
> proper georeferencing for the file in question? Georeferencing that
> makes sense relative to the map area?
> o Offsite handling is different, you may need OFFSITE r g b to get proper
> offsite handling.
> Good luck,
