[Mapserver-users] Mapserver 4 Makefile for VC
Swaminathan, Gayathri
gayathri at ou.edu
Fri Sep 19 11:03:57 EDT 2003
Missed that when looking, but after careful examination saw this file.,
Thanks all as always for your patience and time on this.
Gayathri
-----Original Message-----
From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
Sent: Thursday, September 18, 2003 9:26 PM
To: Swaminathan, Gayathri
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Mapserver 4 Makefile for VC
Hi There,
There are now 2 files involved in the process, makefile.vc and
nmake.opt where all the options are included. This separation makes
things clearer and the option file can be used by sub projects like
php/mapscript.
All settings for necessary libraries + optional libraries are inside the
nmake.opt.
Later,
Swaminathan, Gayathri wrote:
> Hi all:
> After being content with mapserver-3.6.5 for a long time now, I was
> getting ready to compile mapserver 4.0 and test it.
> There are several changes that I notice between mapserver-3.6.5 and
> mapserver-4.0. The makefile.vc in the package shrinked. I assumed this
> is not the One that I should be using and proceeded with alterations
> to my old makefile.vc that came from mapserver-3.6.5
> I was finally sucessful in building a mapserver with the following
> enabled.
> MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> INPUT=EPP L7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I need WMS server and WMS Client with this. I see that libcurl is
> being used somehow and keep getting errors on the same.
> Please, indicate to me the right corrections to makefile.vc (or) tell
> me where am I going wrong in this process.
> Thanks so much for your time on this.
> Gayathri
> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
