[Mapserver-users] WMS using libCurl fails because of a wrong
HTTP User Agent
Daniel Morissette
morissette at dmsolutions.ca
Wed Sep 24 15:07:49 EDT 2003
Norbert Schauerte-Lueke wrote:
> still there is a problem with the UMN wms-client and a propritary WMS
> Server. The diagnostic of the problem show that the WMS Client will
> only send an image when the HTTP User Agent will be MSIE or
> Mozilla. libCurl sets an other HTTP User Agent (somethink like CURL
> Version ...). Is there a possibility to change this HTTP User Agent e.g.
> via an environment variable.
> If anybody can give a hint, I will be very thankfull
I find it really odd that a WMS server would cehck the user agents
before responding to client requests, but anyway, there is apparently a
way to control the user agent value with Libcurl. If you can build from
source, then you could add the following line to maphttp.c around line
339, just after the line that sets CURLOPT_URL:
curl_easy_setopt(http_handle, CURLOPT_USERAGENT, "whatever you want");
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
