[Mapserver-users] WMS using libCurl fails because of a wrong HTTP User Agent
Norbert Schauerte-Lueke
nsl at regio-gis-planung.de
Thu Sep 25 04:46:26 EDT 2003
Hi Daniel,
thank you very much. It works!!!
Norbert
On 24 Sep 2003 at 15:07, Daniel Morissette wrote:
> Norbert Schauerte-Lueke wrote:
> > still there is a problem with the UMN wms-client and a propritary WMS
> > Server. The diagnostic of the problem show that the WMS Client will
> > only send an image when the HTTP User Agent will be MSIE or
> > Mozilla. libCurl sets an other HTTP User Agent (somethink like CURL
> > Version ...). Is there a possibility to change this HTTP User Agent e.g.
> > via an environment variable.
> > If anybody can give a hint, I will be very thankfull
> I find it really odd that a WMS server would cehck the user agents
> before responding to client requests, but anyway, there is apparently a
> way to control the user agent value with Libcurl. If you can build from
> source, then you could add the following line to maphttp.c around line
> 339, just after the line that sets CURLOPT_URL:
> curl_easy_setopt(http_handle, CURLOPT_USERAGENT, "whatever you want");
> Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
R E G I O G I S + P L A N U N G G m b H
____________________________________________
www.regio-gis-planung.de
Falkstraße 73-77, 47058 Duisburg
Tel. 0203 / 30511-360
Fax: 0203 / 30511-364
Hainhölzer Strasse 5, 30159 Hannover
Tel. 0511 / 123577-0
Fax: 0511 / 123577-11
