[Mapserver-users] OGC-compliant
WMS-server deliveringdynamiclayerswith MS?
Debbie Pagurek
pagurekd at agr.gc.ca
Tue Sep 30 14:06:16 EDT 2003
Right, OK.
I can do this:
$image=$map->draw();
and then
$image->saveImage("");
(saveImage is only available for an image object, not a map object).
Thanks again, Daniel.
Debbie
>>> Daniel Morissette <morissette at dmsolutions.ca> 09/30/03 12:20PM >>>
Debbie Pagurek wrote:
> as per some suggestions from Daniel Morissette, I have made a change
to
> my script so that it doesn't do a redirect to result in an image,
> instead, the script outputs an image directly using PHP readfile
> function.
Actually, after our email exchanges yesterday I realized that you could
save the temporary image + readfile() steps if you called
$map->saveImage("") with an empty filename. When it is passed an empty
filename, saveImage() sends its output to stdout, i.e. directly to the
client. I promise it's the last time I suggest a change, it can't get
any shorter than that. ;)
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
