[Mapserver-users] HOW TO ADD LABELS TO POLYGONS/POINTS ?
Tyler Mitchell
TMitchell at lignum.com
Thu Apr 1 11:54:43 EST 2004
You need to specify a LABELITEM (aka field or column from shape file dbf)
in the LAYER definition so that it knows where to grab the text from.
Make sense?
mapserver-users-admin at lists.gis.umn.edu wrote on 04/01/2004 06:13:12 AM:
> Hi all
> After much of work TIGER files directly with OGR connection I found
that
> adding layers is a fun with shp files !! I jus downloaded esri shape
files
> for couple of counties and its real good. But I am fighting to add
labels to
> the water polygon and landmark points layers . I have shape files for
> /Water Polygons /Landmark Polygons /Land polygons /Geo graphic
locations .
> But addition of LABEL item to water polygon does nt work and also the
> Geographic locations layer is not displayed at all !!! and same way
labels
> are not added to the land polygons ...This is my map file ...could any
of
> you help me ??
> LAYER
> GROUP tigerdata
> NAME tgr33015wat
> TYPE POLYGON
> STATUS DEFAULT
> DATA "NH-RM/tgr33015wat"
> CLASS
> NAME "Water Polygons"
> COLOR 0 200 0
> LABEL
> MINFEATURESIZE 20
> MINDISTANCE 100
> BUFFER 10
> ANGLE auto
> POSITION auto
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> COLOR 200 0 0
> OUTLINECOLOR 255 255 255
> ANTIALIAS true
> END
> END
> END # layer ends
> LAYER
> GROUP tigerdata
> NAME tgr33015lpy
> TYPE POLYGON
> STATUS DEFAULT
> DATA "NH-RM/tgr33015lpy"
> CLASS
> NAME "land Polygons"
> COLOR 130 130 130
> END
> END # layer ends
> LAYER
> GROUP tigerdata
> NAME tgr33015kgl
> TYPE POINT
> STATUS DEFAULT
> DATA "NH-RM/tgr33015kgl"
> CLASS
> NAME "Ket Geo Locns"
> COLOR 0 200 0
> END
> END # layer ends
> _________________________________________________________________
> Get the best deals. On Electronics, Mobiles, Laptops. Log on to
> www.baazee.com http://go.msnserver.com/IN/45530.asp
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
