[Mapserver-users] addPoint problems
Ken-ichi Ueda
kueda at wso.williams.edu
Fri Apr 2 22:38:31 EST 2004
Hi folks. I'm new to MapServer and phpMapScript and I've run into a
roadblock with ShapefileObj's addPoint() function. I add the point,
add a record to the dbf (w/ almost no data), there are no errors, and
the reported number of shapes in the file increases by one, but the new
point isn't displayed. I've perused the list archives and haven't
found anything like this. Can anyone give me any advice? This may all
stem from some deep ignorance of the true and potentially infernal
nature of shapefiles. I've included my version info and code below if
it helps. This is all in Mac OS 10.3.
MapServer Version
MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
INPUT=SHAPEFILE
PHP MapScript Version
($Revision: 1.177 $ $Date: 2003/07/30 19:01:31 $)
$my_point = ms_newpointObj();
$my_point->setXY($HTTP_POST_VARS["mapa_x"],$HTTP_POST_VARS["mapa_y"]);
//add the point
$targetFile = ms_newShapefileObj( "/path/to/file", -2 );
$temp = $targetFile->addPoint( $my_point );
echo "<p>result: $temp\n";//test
echo "<p>result: " . $targetFile->numshapes;//test
echo "<p>result: " . $targetFile->type;//test
echo "<p>result: " . $targetFile->source;//test
$targetFile->free();
//add the dbf record
$dbf = dbase_open( "/path/to/file.dbf", 2 );
$attr = array( "", "", "", "", "", "", "", "", "", "", "", "", "",
"", "", "", "", "", "", "", "", "", "", "", "", "", "", "newpt", "",
if( !dbase_add_record( $dbf, $attr ) ) echo "<h2>Add Record
Failed!</h2>";
dbase_pack( $dbf );
Thanks in advance.
-Ken-ichi
