[Mapserver-users] Multiple counties in a template file !!!
Dharani Babu
dharanibabus at hotmail.com
Sat Apr 3 01:14:43 EST 2004
Steve & Tyler
Thanks for your reply . good help for me . I have also posted another
message on Win CE version comonent developement of map server( titled "Win
CE version ") . Please add your points also .
with regards and thanks in advance
dharani
>From: Stephen Woodbridge <woodbri at swoodbridge.com>
>To: Dharani Babu <dharanibabus at hotmail.com>
>CC: TMitchell at lignum.com, mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] Multiple counties in a template file !!!
>Date: Fri, 02 Apr 2004 00:37:44 -0500
>Dharani,
>A tileindex is a collection of files that all have the same structure and
>could all be concatenated together but aren't because it is easier to work
>with and manage a bunch of smaller files. The other advantage is that there
>are some significant performance improvements that can be had by working
>with data organized using tileindexes.
>Here is what I do for shapefiles. Say you have a layer called streets.shp
>and you have 10 counties each with its streets.shp file in a separate
>directory like:
>data/county01/streets.shp
>data/county02/streets.shp
>data/county09/streets.shp
>data/county10/streets.shp
>find ./data/ -name streets.shp -print > streets.in
>tile4ms streets.in streets-tile
>find . -name "*.shp" -exec shptree {} \;
>This will find all your streets.shp files and create a tileindex called
>streets-tile.shp and also find all shapefiles and create a spatial index
>for them.
>Now in your mapfile
>LAYER
>NAME "streets"
>TILEINDEX "streets-tile.shp"
>END
>You need to read up on this in the mapfile reference and the utilities doc
>pages on the mapserver website.
>You can see all of the US Tiger data at http://imaptools.com/tiger/
>-Steve
>Dharani Babu wrote:
>>hi Steve
>>Thanks . That has set me on . though yet to know what tileindex is . I
>>appreciate the way the map server members helping each other out- have
>>seen forums which hardly reply to queries . i will update u of my progress
>>soon.
>>dharani babu s
>>>From: woodbri at swoodbridge.com
>>>Reply-To: woodbri at swoodbridge.com
>>>To: "Dharani Babu" <dharanibabus at hotmail.com>, Tyler
>>>Mitchell <TMitchell at lignum.com>
>>>CC: mapserver-users at lists.gis.umn.edu
>>>Date: Thu, 01 Apr 2004 14:51:59 -0500
>>>But if you have all the data in the US it is 3300 counties plus or
>>>minus and you probably don't want 3300 layers for each attribute.
>>>What you want to do is use a tileindex. This will allow you to treat
>>>all roads files in all 3300 counties as a single layer.
>>>-Steve W.
>>>On 1 Apr 2004 at 8:53, Tyler Mitchell wrote:
>>> > I assume you mean you have multiple TIGER files and want to have them
>>> > appended into one map, right?
>>> > If you have all the data for multiple counties, then you just add each
>>>one
>>> > as a layer and it will make them work seamlessly together.
>>> > mapserver-users-admin at lists.gis.umn.edu wrote on 04/01/2004 06:16:02
>>>AM:
>>> > > Hi all
>>> > > Could any of you advise me how I could display multiple counties(
>>>or
>>> > a
>>> > > full state) in the same map ?. After displaying them I want to have
>>>the
>>> > > same set of operations like zooming in /out/pan as we have with
>>>single
>>> > > county maps .
>>> > > With regards and thanks in advance
>>> > > dharani babu s
>>> > > _________________________________________________________________
>>> > > Apply to 50,000 jobs now. http://go.msnserver.com/IN/45531.asp Post
>>>your
>>> > CV
>>> > > on naukri.com today.
>>> > > Mapserver-users mailing list
>>> > > Mapserver-users at lists.gis.umn.edu
>>> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>Easiest Money Transfer to India. Send Money To 6000 Indian Towns.
>>http://go.msnserver.com/IN/42198.asp Easiest Way To Send Money Home!
Old pals, ex-flames, great times. Catch up with the past! Sign up now!
http://www.batchmates.com/msn.asp
