[Mapserver-users] Need help with SDE connection
Oliver Wesp wesp at gdv.com
Mon Apr 5 02:38:10 PDT 2004
If msSDELayerOpen() fails the problem is most likely the
Client-Connection. This could be due to an incorrect Connection-String
or to a failure of the client. Can you post the complete Error-Message.
Oliver
Norbert Thieme wrote:
> Hi,
> thanks for that. Now I got the error message I need. The connection seem
> to work but the msSDELayerOpen() got a problem. So I can go on testing
> if there is still something wrong in my mapfile or if there is a problem
> with the SDE client.
> Once more thanks,
> Norbert
> Oliver Wesp schrieb:
>> Hi,
>> we're using SDE-Connections with some success, so it's not impossible.
>> Although we're using SDE with Oracle8i and 9i.
>> The first thing that comes to my mind is that your SDE-Layer has
>> STATUS=ON in your mapfile. So are you sure the layer is requested? Try
>> STATUS=DEFAULT to make sure it is.
>> best regards
>> Oliver Wesp
>>> Hi all,
>>> I already wrote last week because I have a problem with the
>>> connection to ArcSDE. (Please see:
>>> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0403/msg00748.html)
>>> Sorry for my impatience but I don't get any further at this point and
>>> I really need this problem to be solved. If someone has an idea
>>> please tell me. I would be very glad.
>>> If there is no way to get the problem solved directly with SDE I need
>>> to access Informix with OGR - SQL. Although this wouldn't be the
>>> preferred way: If someone can give me an advise on this it would be
>>> very nice as well.
>>> Thanks for your help,
>>> Norbert
>>> Bundesanstalt für Wasserbau  *  FIT Ilmenau  *  Referat IT2
>>> Am Ehrenberg 8  *  98693 Ilmenau  *  Germany
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dipl.-Geogr. Oliver Wesp
Gesellschaft fuer geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
More information about the MapServer-users mailing list
