[Mapserver-users] WMS requests.
Bob Basques
bob.basques at ci.stpaul.mn.us
Mon Apr 5 15:41:06 EDT 2004
All,
While puttering with WMS functionality and MapServer.
I got a valid getCapabilities request to work ok, the XML stream comes
back out real nicely, but when I try to run a GetMap request, I get a
LAYER error back to the effect of :
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.0">
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in
the LAYERS parameter.
</ServiceException>
</ServiceExceptionReport>
I think it has to do with how I have my LAYERs defined. Would a DEFAULT
setting on all layers mess up the WMS output for example? See my
Mapfile below, I have different sets of resolutiuon for each zoom
range, shouldn't just the topmost be used for a default Map Generation
(if I read the WMS how-to correctly) require only the top level Zoom
values, regardless of whether the other LAYERS are set to Default. I
don't have any overlap (I don't think) in the LAYER definitions.
The Images output in non-WMS just fine BTW.
Thanks for any insight here.
bobb
# Start of map file
MAP
NAME HORIZONS
STATUS ON
SIZE 600 600
EXTENT 540000 135000 600000 175000
UNITS FEET
SHAPEPATH "./data"
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
WEB
METADATA
WMS_TITLE "WMS City of Saint Paul, Public Works Server"
WMS_ONLINERESOURCE
"http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?map=../html/raster/horizons_wms.map&"
WMS_SRS "EPSG:32615"
END
##PROJECTION
##"init=epsg:32615"
##END
END
LAYER
NAME "L5"
METADATA
WMS_TITLE "HORIZONS L5"
WMS_GROUP_TITLE "AERIAL"
END
STATUS DEFAULT
TILEINDEX "RAST_RAM_PW_AER_SUR_2003_04_L5"
TILEITEM "Location"
TYPE RASTER
GROUP "AERIAL"
MINSCALE 16001
MAXSCALE 32000
END
LAYER
NAME "L4"
METADATA
WMS_TITLE "HORIZONS L4"
END
STATUS DEFAULT
TILEINDEX "RAST_RAM_PW_AER_SUR_2003_04_L4"
TILEITEM "Location"
TYPE RASTER
GROUP "AERIAL"
MINSCALE 8001
MAXSCALE 16000
END
LAYER
NAME "L3"
METADATA
WMS_TITLE "HORIZONS L3"
END
STATUS DEFAULT
TILEINDEX "RAST_RAM_PW_AER_SUR_2003_04_L3"
TILEITEM "Location"
TYPE RASTER
GROUP "AERIAL"
MINSCALE 4001
MAXSCALE 8000
END
LAYER
NAME "L2"
METADATA
WMS_TITLE "HORIZONS L2"
END
STATUS DEFAULT
TILEINDEX "RAST_RAM_PW_AER_SUR_2003_04_L2"
TILEITEM "Location"
TYPE RASTER
GROUP "AERIAL"
MINSCALE 2001
MAXSCALE 4000
END
LAYER
NAME "L1"
METADATA
WMS_TITLE "HORIZONS L1"
END
STATUS DEFAULT
TILEINDEX "RAST_RAM_PW_AER_SUR_2003_04_L1"
TILEITEM "Location"
TYPE RASTER
GROUP "AERIAL"
MINSCALE 1001
MAXSCALE 2000
END
LAYER
NAME "L0"
METADATA
WMS_TITLE "HORIZONS L0"
END
STATUS DEFAULT
TILEINDEX "RAST_RAM_PW_AER_SUR_2003_04_L0"
TILEITEM "Location"
TYPE RASTER
GROUP "AERIAL"
MINSCALE 501
MAXSCALE 1000
END
END # Map File
