[Mapserver-users] Label TEXT Display Trouble PHP Mapscript
Mark Fennell mfennell at markfennell.com
Tue Apr 6 16:26:20 PDT 2004
Hi. I Have sucessfully got PHPmapscript to extract a series of points from a
database, and then display the points on a map. (PHP code is below, it
should be relatively easy to follow and is made up from the various posts
around this mailing list)
The MAP code is also detailed below as well. I am setting the points to
display with SetXY, and then labelling them (I think) with the
$pointObj->draw($map, $layerObj, $image, 0, $show["Name"]); part.
I can display the points but Not the Text Label, whiich is What I really
want to do! Any help apppreciated.
Mark Fennell
-------8<----PHP File------------
<html>
<?php
  dl("php_mapscript.so");
 $map_path="/Users/markfennell/Existing/adventure/wwwroot/map/";
 $map = ms_newMapObj($map_path."dynamic.map");
printf("Map name=%s, num lay=%d<br>\n", $map->name, $map->numlayers);
for ($i=0; $i<$map->numlayers; $i++) {
  $myLayer = $map->getLayer($i);
  printf("Layer num=%d, name=%s <br>\n", $i, $myLayer->name);
echo"<br>";
 //mysql_q
// Dirty hack to make query
$db = mysql_connect("localhost", "root", "Slaine2k");
mysql_select_db("adventurelocations",$db);
$results = mysql_query("SELECT * FROM Location",$db);
if ($results === false) die("failed");
//drawPoints
$layerObj = $map->getLayerByName("points");
$image = $map->draw();
$pointObj = ms_newPointObj();
while ($show = mysql_fetch_array($results, MYSQL_ASSOC)) {
    $pointObj->setXY($show["Longitude"], $show["Latitude"], 0);
    // draw the point on the image, using the id attribute to label it
    echo
$show["Latitude"]." ".$show["Longitude"]." ".$show["Name"]."<br>\n
 $image_url=$image->saveWebImage(MS_PNG,1,1,0);
  <HTML>
      <HEAD>
         <TITLE>MYSQL sample</TITLE>
     </HEAD>
     <BODY>
         <IMG SRC=<?php echo $image_url; ?> >
    </BODY>
</HTML>
------8<------------MAP----------------
MAP
    NAME "Australia"
    SIZE 400 300
    IMAGETYPE PNG
    EXTENT 112.9211349 -43.65853882 153.63974 -9.984018326
    SHAPEPATH "/Users/markfennell/Existing/adventure/wwwroot/map/data"
    FONTSET
"/Users/markfennell/Existing/adventure/wwwroot/map/tutorial/fonts/fonts.list
    WEB
        IMAGEPATH "/Users/markfennell/Existing/adventure/wwwroot/map/tmp/"
        IMAGEURL "/adventure/wwwroot/map/tmp/"
    END
    IMAGECOLOR 255 255 255
    PROJECTION
        "proj=merc"
        "lat_0=0"
        "lon_0=0"
    END
    SYMBOL
      TYPE ELLIPSE
      NAME "circle"
      POINTS 1 1 END
      FILLED TRUE
    END
    # Start of LAYER DEFINITIONS
    LAYER
    NAME "au"
    DATA "au_coast"
    STATUS DEFAULT
    TYPE POLYGON
    PROJECTION
        "proj=merc"
        "lat_0=0"
        "lon_0=0"
    END
    CLASS
        COLOR 232 232 232
        OUTLINECOLOR 32 32 32
    END
    END # End Australia Coast
LAYER
  NAME "points"
  TYPE POINT
    PROJECTION
        "proj=merc"
        "lat_0=0"
        "lon_0=0"
    END
  CLASS
    SYMBOL "circle"
    SIZE 6
    COLOR 255 0 0
    OUTLINECOLOR 0 0 0
      LABEL
        COLOR 132 31 31
        SHADOWCOLOR 218 218 218
        SHADOWSIZE 2 2
        TYPE TRUETYPE
        FONT arial-bold
        SIZE 12
        ANTIALIAS TRUE
        POSITION CL
        PARTIALS FALSE
        MINDISTANCE 300
        BUFFER 4
    END # end of label
  END
END
    # End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
More information about the MapServer-users mailing list
