[Mapserver-users] Stile problem with SWF and fdb fonts
mapserver at no-log.org
Wed Apr 7 07:36:08 EDT 2004
Hi Ray,
I've partially solved the problem.
Your font type must be defined as truetype and not bitmap when using fdb
fonts.
LABEL
TYPE truetype
FONT "your_font"
END
If you use shp2img, same issue ?
shp2img -m your_mapfile.map -o test.swf
I've experienced some crashs when rendering fonts with ming.
I can't use php mapscript module and php ming module at the same time.
(under linux php_mapscript.so and php_ming.so). All works fine but when i
try to render an swf object which uses fonts using the ming module i get
an internal server error.
I'll check the latest release from cvs, i've reported the bug it is maybe
solved ;)
I expect it will help
Christophe Beveraggi
> I am having this same issue. I'm running mapserver 4.0.1 with ming v0.3a
> on
> a Solaris 8 (sparc) box. I was getting an internal server error with 4.0.1
> then I switched to the latest nightly build and no more internal errors.
> But
> I don't get any fonts showing up at all. Also I am using .fdb fonts
> directly
> from the ming site. Everything else seems to be working just fine all the
> layers are displayed and look great I just don't have any labels...
> Has anyone run into this same problem? or better yet resolved it?....I'm
> not
> sure what else to try at this point since I'm no longer recieving any
> error
> messages at all....any help would be appreciated...
> Ray,
> OUTPUTFORMAT
> NAME swf
> DRIVER "SWF"
> MIMETYPE "application/x-shockwave-flash"
> EXTENSION "swf"
> IMAGEMODE PC256
> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE FULL_RESOLUTION=FALSE"
> END
> LABELITEM "name"
> CLASS
> MAXSCALE 10000
> NAME 'Local Road'
> COLOR 131 132 125
> SYMBOL 'circle'
> SIZE 2
> LABEL
> TYPE BITMAP
> ANTIALIAS FALSE
> ANGLE AUTO
> POSITION uc
> FONT "sans-fdb"
> COLOR 0 30 50 #51 51 51
> OUTLINECOLOR 255 255 255
> SIZE SMALL
> PARTIALS FALSE
> BUFFER 1
> END
> END
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of
> Sent: Friday, March 19, 2004 10:40 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Stile problem with SWF and fdb fonts
> Hi,
> First, s/Stile/Still in subject sorry ;)
> New strange thing, all layers are rendered correctly with
> OUTPUT_MOVIE=multiple using fdb fonts when i use shp2img with my mapfile.
> Always internal server error using php_mapscript and apache with multiple
> swf layers rendering, and no problem with unique layer rendering
> (OUTPUT_MOVIE=single).
> Any help would be appreciated :)
> Sample of the layer:
> LAYER
> NAME "Regions"
> TYPE line
> DATA "lim_adm_france_dom"
> STATUS on
> DEBUG on
> CLASSITEM 'NATURE'
> LABELITEM 'ID_GEOFLA'
> CLASS
> DEBUG on
> NAME 'regions'
> EXPRESSION ('[NATURE]' eq 'Limite de région')
> SIZE 3
> COLOR 255 0 0
> SYMBOL "circle"
> LABEL
> TYPE bitmap
> FONT "verdana"
> COLOR 0 0 0
> SIZE 12
> MAXSIZE 18
> POSITION CC
> ANGLE AUTO
> BUFFER 2
> END
> END
> PROJECTION
> "init=epsg:2154"
> END
> TOLERANCE 5
> END
> Thanks
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
