[Mapserver-users] Compiling PHP_MapScript.dl...
Mike Leahy
mgleahy at fes.uwaterloo.ca
Thu Apr 8 17:14:02 EDT 2004
You were right about the DLLs - in my haste I forgot to update them.
This is cool - I'll have to try it out tonight after I get PostGIS updated.
Thanks again for your help.
Mike
Quoting Yewondwossen Assefa <assefa at dmsolutions.ca>:
> I just tried the function using a small script with the dll posted :
> <?php
> dl ("php_mapscript_41.dll");
> echo ms_getversion();
> results are
> MapServer version 4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> It seems to me that the php mapscript dll module did not load on your
> machine for some reason (common problem being some dll's related to
> mapserver library were not loaded). My best guess is maybe, you did not
> install the libpq dll (which is related to the postgis and available in
> the zip). But this is just a guess. I also suggest that you use a tool
> like depend.exe (http://www.dependencywalker.com/) that let you identity
> if you miss some dependent dlls.
> Later,
This mail sent through www.mywaterloo.ca
