RES: RES: [Mapserver-users] Problems Compiling GDAL1.1.9 + MapServer
Daniel Morissette
dmorissette at dmsolutions.ca
Mon Apr 12 13:56:10 PDT 2004
Gabriel Moricz wrote:
> Thanks For the Light Daniel...
> The error have changed now...hehehehehe..
> error:
> /usr/bin/ld: warning: libpq.so.3, needed by ../libgdal.1.1.so, not found
> (try using -rpath or -rpath-link)
There seems to be a problem with libpq.so.3 not being found.
Is there a libpq.so.3 in /usr/local/pgsql/lib/ on your system?
There used to be a "-L/usr/local/pgsql/lib -lpq" in your link line
before, is it still there?
Note that for libpq.so.3 to be found at runtime, you'll also need to add
/usr/local/pgsql/lib to /etc/ld.so.conf and then run 'ldconfig' as root.
However that's probably not going to fix your current problem since you
don't have an executable yet.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
More information about the MapServer-users
