RES: [Mapserver-users] Problems Compiling GDAL1.1.9 + MapServer
Gabriel Moricz gabriel at autofax.com.br
Tue Apr 13 05:42:17 PDT 2004
Hey Daniel...
As I said before...it have worked for gdal, but my mapserver isnt making..
My Configure:
./configure --with-jpeg=/usr --with-freetype=/usr --with-gd=/usr/local --wit
h-freetype=/usr/local --with-proj=/usr/local --with-gdal=/usr/local/bin/gdal
-config --with-ogr=/backup/mapserv/gdal-1.1.9 --with-curl=/usr/local/bin --w
ith-wmsclient --with-ming --with-postgis=/usr/local/pgsql/bin/pg_config --wi
th-wms --with-wfsclient --with-httpd=/usr/sbin/apache
and the error is:
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_AP
I_H -DUSE_WMS_SVR -DUSE_WMS_LYR    -DUSE_MING_FLASH    -DUSE_GD_GIF -DUSE_GD
_PNG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DUSE_PDF   -DUSE_GDAL
 -DUSE_POSTGIS    -I/usr/local/include  -I/usr/local/include       -I/usr/lo
cal/include -I/usr/local/pgsql/include  -I/usr/local/include   shp2img.c -o
shp2img.o
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H
 -DUSE_WMS_SVR -DUSE_WMS_LYR    -DUSE_MING_FLASH    -DUSE_GD_GIF -DUSE_GD_PN
G -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DUSE_PDF   -DUSE_GDAL -D
USE_POSTGIS    -I/usr/local/include  -I/usr/local/include       -I/usr/local
hp2img.o  -L. -lmap -L/usr/local/lib -lgd -ljpeg -lfreetype -lpng -lz   -lpd
f -ljpeg -lfreetype -lpng -lz   -L/usr/local/lib -lproj -ljpeg  -L/usr/local
/lib -lgdal.1.1 -lming -L/usr/local/pgsql/lib -lpq  -L/usr/local/lib -lcurl
-lz -ldl -lz    -lm  -o shp2img
./libmap.a(mappdf.o): In function `msDrawMarkerSymbolPDF':
mappdf.o(.text+0x1b26): undefined reference to `gdImageJpegPtr'
./libmap.a(mappdf.o): In function `msDrawRasterLayerPDF':
mappdf.o(.text+0x22c4): undefined reference to `gdImageJpegPtr'
./libmap.a(mappdf.o): In function `msSaveImagePDF':
mappdf.o(.text+0x2536): undefined reference to `gdImageJpegPtr'
./libmap.a(mappdf.o): In function `msDrawWMSLayerPDF':
mappdf.o(.text+0x2dca): undefined reference to `gdImageJpegPtr'
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
And Now...any idea?
Thanksss..
Gabriel Moricz
-----Mensagem original-----
De: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Em nome de Daniel
Morissette
Enviada em: segunda-feira, 12 de abril de 2004 17:56
Para: Gabriel Moricz
Cc: mapserver-users at lists.gis.umn.edu
Assunto: Re: RES: RES: [Mapserver-users] Problems Compiling GDAL1.1.9 +
Gabriel Moricz wrote:
> Thanks For the Light Daniel...
> The error have changed now...hehehehehe..
> error:
> /usr/bin/ld: warning: libpq.so.3, needed by ../libgdal.1.1.so, not found
> (try using -rpath or -rpath-link)
There seems to be a problem with libpq.so.3 not being found.
Is there a libpq.so.3 in /usr/local/pgsql/lib/ on your system?
There used to be a "-L/usr/local/pgsql/lib -lpq" in your link line
before, is it still there?
Note that for libpq.so.3 to be found at runtime, you'll also need to add
/usr/local/pgsql/lib to /etc/ld.so.conf and then run 'ldconfig' as root.
However that's probably not going to fix your current problem since you
don't have an executable yet.
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
