[Mapserver-users] PostGIS blank error - bit of a newbie question....!
Paul Ramsey
pramsey at refractions.net
Tue Apr 13 11:36:01 EDT 2004
Is there a valid entry for your table in geometry_columns?
Is there a valid entry for your srid in spatial_ref_sys?
Can you put the SQL from the error message (minus the DECLARE statement)
into psql and get something back?
Matt Hatcher wrote:
> Hi,
> I'm trying to get a postgres connection working with Mapserver 4.0.1 on
> Mandrake 9.2. I'm using the Postgres and Postgis RPMs from the postgis
> site, and the stable 4.0.1 source compiled with the postgis option. My -v
> gives:
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> I've got a table that I loaded from a point shapefile using shp2pgsql
> which I can query quite happily from the psql command line. The data in
> there is in SRID 4326, e.g.:
> gid | id | x | y | height_m | height_ft | type |
> name | the_geom
> | 1 | -5.003492 | 56.796264 | 1343.798 | 4408.786096 | Munro | Ben
> Nevis | SRID=4326;POINT(-5.003492 56.796264)
> When I try and get the data through Mapserver I get the following
> unhelpful "blank" error message:
> msDrawMap(): Image handling error. Failed to draw layer named 'peaks'.
> prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query)
> statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
> mountains WHERE the_geom && setSRID('BOX3D(-10.5612147941099
> 48.9367546675052,6.81724902590237 55.7611851275149)'::BOX3D,
> find_srid('','mountains','the_geom') )'
> Postgresql reports the error ''
> More Help:
> Error with POSTGIS data variable. You specified '<check your .map file>'.
> Standard ways of specifiying are :
> (1) 'geometry_column from geometry_table'
> (2) 'geometry_column from (<sub query>) as foo using unique <column name>
> using SRID=<srid#>'
> Make sure you put in the 'using unique <column name>' and 'using SRID=#'
> clauses in.
> For more help, please see http://postgis.refractions.net/documentation.php
> Mappostgis.c - version of June 12/2003.
> My map file has:
> LAYER
> NAME "peaks"
> TYPE POINT
> STATUS OFF
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=apache dbname=geo"
> DATA "the_geom from mountains"
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> SYMBOL 'circle'
> SIZE 4
> COLOR 0
> END
> END
> Any suggestions would be gratefully received!
> Cheers, Matt.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
