[Mapserver-users] PostGIS blank error - bit of a newbie
question....!
Matt Hatcher
matt at phyreworks.com
Tue Apr 13 11:54:40 EDT 2004
Paul,
Thanks. You've indirectly solved my problem!
I did have a valid entry in both geometry_columns and spatial_ref_sys, but
I hadn't granted permissions on them to my webserver user. I'd granted to
the table itself but not the metadata tables.
It works like a dream now!
Matt.
> Is there a valid entry for your table in geometry_columns?
> Is there a valid entry for your srid in spatial_ref_sys?
> Can you put the SQL from the error message (minus the DECLARE statement)
> into psql and get something back?
> Matt Hatcher wrote:
>> Hi,
>> I'm trying to get a postgres connection working with Mapserver 4.0.1 on
>> Mandrake 9.2. I'm using the Postgres and Postgis RPMs from the postgis
>> site, and the stable 4.0.1 source compiled with the postgis option. My
>> -v
>> gives:
>> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
>> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=JPEG INPUT=POSTGIS
>> INPUT=OGR
>> INPUT=GDAL INPUT=SHAPEFILE
>> I've got a table that I loaded from a point shapefile using shp2pgsql
>> which I can query quite happily from the psql command line. The data in
>> there is in SRID 4326, e.g.:
>> gid | id | x | y | height_m | height_ft | type |
>> name | the_geom
>> | 1 | -5.003492 | 56.796264 | 1343.798 | 4408.786096 | Munro | Ben
>> Nevis | SRID=4326;POINT(-5.003492 56.796264)
>> When I try and get the data through Mapserver I get the following
>> unhelpful "blank" error message:
>> msDrawMap(): Image handling error. Failed to draw layer named 'peaks'.
>> prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual
>> query)
>> statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
>> asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
>> mountains WHERE the_geom && setSRID('BOX3D(-10.5612147941099
>> 48.9367546675052,6.81724902590237 55.7611851275149)'::BOX3D,
>> find_srid('','mountains','the_geom') )'
>> Postgresql reports the error ''
>> More Help:
>> Error with POSTGIS data variable. You specified '<check your .map
>> file>'.
>> Standard ways of specifiying are :
>> (1) 'geometry_column from geometry_table'
>> (2) 'geometry_column from (<sub query>) as foo using unique <column
>> name>
>> using SRID=<srid#>'
>> Make sure you put in the 'using unique <column name>' and 'using SRID=#'
>> clauses in.
>> For more help, please see
>> http://postgis.refractions.net/documentation.php
>> Mappostgis.c - version of June 12/2003.
>> My map file has:
>> LAYER
>> NAME "peaks"
>> TYPE POINT
>> STATUS OFF
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "user=apache dbname=geo"
>> DATA "the_geom from mountains"
>> PROJECTION
>> "init=epsg:4326"
>> END
>> CLASS
>> SYMBOL 'circle'
>> SIZE 4
>> COLOR 0
>> END
>> END
>> Any suggestions would be gratefully received!
>> Cheers, Matt.
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
