[Mapserver-users] problème avec la commande EXPRESION
Emmanuel CAPELLI
e.capelli at iaat.org
Wed Apr 14 05:51:09 EDT 2004
Hello,
We recently try to install a "Serveur Cartographique" with Mapserver.
We encounter a problem when we want to select objects.
With the "command" EXPRESSION we can select our objects starting from the
codes (text). But it selects also a character in the chain, Example:
EXPRESSION /1/ it goes up object having code 1 but also code 14, 51, 100,
etc.
Thank you by advance for your assistance
Emmanuel CAPELLI
LAYER
NAME ZA
TYPE POINT
DATA ZA
STATUS DEFAULT
CLASSITEM 'V_ZA_CODE_'
CLASS
NAME "Zone d'activité"
EXPRESSION /./
COLOR 0 255 0
SYMBOL 'circle'
SIZE 7
TEMPLATE "ZA.html"
END
HEADER "ZA_header.html"
FOOTER "ZA_footer.html"
TOLERANCE 5
DUMP TRUE # allow GML export
METADATA
WMS_TITLE "Zone d'activité"
WMS_ABSTRACT "Numérisation des Za par la DDE 79"
WMS_SRS "EPSG:4326"
END
END
