[Mapserver-users] problème avec la commande EXPRESION {Scanned} {Scanned}
Siki Zoltan
siki at agt.bme.hu
Wed Apr 14 10:39:30 EDT 2004
Hello,
In Mapserver regular expressions are used in expressions if you put it
between slashes, so if you would match only "1" then your expression is /^1$/.
Or you can use string expression, like "1"?
See map file reference.
Bye
Zoltan
On Wed, 14 Apr 2004, Emmanuel CAPELLI wrote:
> Hello,
> We recently try to install a "Serveur Cartographique" with Mapserver.
> We encounter a problem when we want to select objects.
> With the "command" EXPRESSION we can select our objects starting from the
> codes (text). But it selects also a character in the chain, Example:
> EXPRESSION /1/ it goes up object having code 1 but also code 14, 51, 100,
> etc.
> Thank you by advance for your assistance
> Emmanuel CAPELLI
> e.capelli at iaat.org
> LAYER
> NAME ZA
> TYPE POINT
> DATA ZA
> STATUS DEFAULT
> CLASSITEM 'V_ZA_CODE_'
> CLASS
> NAME "Zone d'activité"
> EXPRESSION /./
> COLOR 0 255 0
> SYMBOL 'circle'
> SIZE 7
> TEMPLATE "ZA.html"
> END
> HEADER "ZA_header.html"
> FOOTER "ZA_footer.html"
> TOLERANCE 5
> DUMP TRUE # allow GML export
> METADATA
> WMS_TITLE "Zone d'activité"
> WMS_ABSTRACT "Numérisation des Za par la DDE 79"
> WMS_SRS "EPSG:4326"
> END
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
