[Mapserver-users] Passing CGI variables
Dharani Babu
dharanibabus at hotmail.com
Wed Apr 14 21:13:29 PDT 2004
Thanks Daniel - all
This helped me get a vb.net picture box based wrapper for the MS . I have
a question though .
As you when we post the CGI variables we are in need of posting it in the
form of a html stream only--like
"http://192.168.2.135/cgi-bin/mapserv_40.exe?zoomdir=1&zoomsize=2&" etc .
But is there any alternative so that I can pass it with
"C:/ms4w/apache/cgi-bin/mapserv_40.exe?zoomdir=1&zoomsize=2&" ?
But I know very well the map server exe works with Apache or IIS . But I
want to copy the map server exe and its associated dlls to a location other
then the cgi-bin or scripts . Is it possible ?
Is there any way we can make MS exe to get the html stream and give us the
image in tmp folder WITHOUT Apache or IIS ? I am trying to get a soln by
running dependency walker on ms exe and other trails with spy tools . Still
not yet solved .
with regards and thanks in advance
dharani
>From: Daniel Morissette <dmorissette at dmsolutions.ca>
>To: Dharani Babu <dharanibabus at hotmail.com>
>CC: mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] Passing CGI variables
>Date: Sat, 10 Apr 2004 11:54:24 -0400
>Dharani Babu wrote:
>>1) I am trying to pass the CGI variables to the map server exe without
>>HTML submission .Thats I am trying to disassociate the browser based
>>rendering .Could any of you point to the direction ?I have been able to
>>pass the url thro a C# /VB.net web browser control . But searching for an
>>alternative . I tried passing CGI variables thro command prompt but got
>>a message that " cgi variables can be passed only via httpd " .
>You can call the mapserv.exe at the command prompt using
> mapserv.exe "QUERY_STRING=map=/path/to/yourmap.map&mode=...&..."
>Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
_________________________________________________________________
Contact brides & grooms FREE! http://www.shaadi.com/ptnr.php?ptnr=hmltag
Only on www.shaadi.com. Register now!
More information about the MapServer-users
