[Mapserver-users] mapscript dl() fails with missing gdImageSetClip symbol
Hal Mueller hal at mobilegeographics.com
Wed Apr 14 23:55:31 PDT 2004
Thanks to some suggestions from list members I have mapserv up and
running, got the itasca demo to draw, and built a second PHP (CGI
version) to run Mapscript.  I have php_mapscript.so copied to the
proper directory (I know this because for a while I didn't!).  I have
edited ld.so.conf, run ldconfig, and restarted httpd.
I'm now trying to do a simple dl(php_mapscript), phpinfo().
When I do this I see
Warning :  dl(): Unable to load dynamic library
'/usr/local/lib/php/extensions/no-debug-non-zts-20020429/php_mapscript.so'
/usr/local/lib/php/extensions/no-debug-non-zts-20020429/php_mapscript.so:
undefined symbol: gdImageSetClip in
/home/virtual/site1/fst/var/www/html/mapscriptTest.phtml on line 11
The installation, and full phpinfo() results including config
switches, are at
http://65.18.157.253/mobilegeographics.com/mapscriptTest.phtml .
Another sample,
http://65.18.157.253/mobilegeographics.com/phpinfo.php, uses the
built-in PHP (4.3.3 instead of 4.3.5).
I believe that what is happening is that php_mapscript needs another
dynamic library to find the GD stuff, but isn't finding it.  But I'm
not sure of that.
Suggestions?
TIA,
Hal
More information about the MapServer-users mailing list
