[Mapserver-users] Preperation for 4.2 release, update of [shpxy...] tag...
Steve Lime
steve.lime at dnr.state.mn.us
Thu Apr 15 11:30:08 EDT 2004
Hi Folks: This is just a heads up for folks using the [shpxy...] tag in
4.1. I've done a bit of
clean up on the tag to make it more useful. Gone is the transform
attribute and there is
a new proj attribute. That attribute allows you to specify an output
projection for a feature.
You can set proj="image" to output the feature in image coordinates
suitable for an
imagemap. Otherwise proj takes a Proj.4 projection string. Note that
the layer associated
with a feature must contain a projection object. There still may be
issues with "image"
coordinates IF the output map is in a different coordinate system than
the layer.
Without any proj attribute coordinates (at this point) are given in the
native projection
of the layer.
Any help testing would be appreciated!
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
