[Mapserver-users] scripting languages
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Fri Apr 16 08:00:10 EDT 2004
MapServer is not a full featured GIS and it's not your purpose. Its main
goals is to provide a powerfull set of resources to develop spatially
enabled internet applications.
It can operated using the CGI mode, which is basically set with a
MapFile(configuration file for the mapserver application) and Template
files - these ones define the interface of users, layout, etc...
Or you can use MapScript mode. MapScript provides for some languages as
Perl, PHP, Java, Python, Ruby, the API functions which is contained in
MapServer. So, you'll be able to build a more complex and flexible
system if you use MapScript with some language.
There's some functions of spatial analisys in MapScript set, but you can
also combine MapScript with another toolset or library. eg.: if you need
functions for computing path alternatives you could a library/class to
do that, and use MapScript to show results.
best.
http://www.consultoria.eti.br
## Projeto MapServer Brasil - http://mapserver.cttmar.univali.br ##
***Fim da Mensagem / End of Message ***
Saurabh Data escreveu:
> Dear users
> Can someone give me more information about the scripting languages
> Mapserver uses like perl, PHP and others. What is their purpose.
> Someone told me that it can be used for spatial analysis. I am not a
> programmer so dont know at all as to how Mapserver benefits by using
> the languages. CAn someone clarify if at all it is used for spatial
> analysis. In not, then what is its purpose
> Many Thanks
> Saurabh Data
> ___________________________________________________________________
> Saurabh Data
> School of Computing
> University of Leeds
> Leeds LS2 9JT
> U.K.
> one who seeketh , will findeth and all door shall open - james Allen
> Tired of 56k? Get a FREE BT Broadband connection
> http://www.msn.co.uk/specials/btbroadband
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
