[Mapserver-users] mapserv cgi and raster layers
Andrew
selkiesdad at twcny.rr.com
Fri Apr 16 10:59:40 EDT 2004
I have a correction...I found the correct use of DEBUG in the docs and
traced the cgi mapserv process. The landsat file failes with
"msDrawMap() Image handling" error, the tiff files abort the cgi before
any log is made. Removing the offending tiffs from the path and trying
to map them anyway gives "normal execution" concerning the missing rsater.
Andrew wrote:
> I have compiled the mapserv cgi and all the required libraries and
> associated utilities from source on an ix86 Linux slackware (kernel
> 2.4.20) box. I have tried both the mapserver 4.0 and 4.02 source
> files with gdal 1.2, gd 2.0.22, freetype 2.1.7 and proj 4.4.7. I had
> no problems with the compiles ( except for the --with-ogr option for
> mapserv 4.0 which required manual fixes to the Makefile paths for ogr
> includes and libs). I have used the tutorial.zip file downloaded from
> the mapserver documentation links online, fixed the mixed windows/unix
> paths and locations, and eliminated the instances of '\r\n' with '\n'
> in all text files, including tiff world files and the html template
> files. I have recompiled repeatedly using various combinations of the
> --with-odbc and --with-ogr options for gdal and mapserve. I have a
> serious and inexplicable problem with the display of raster layers.
> They don't.
> Any map file references to tiff files that are actually in the
> location listed causes a cgi abort with a "premature end of script
> headers" upon mapping them as backgrounds. Neither version of
> mapserver sources will permit the use of the DEBUG option in ANY
> location in the map file without aborting with an appropriate message.
> The mapserv cgi fails in the wms connect to the landsat data source
> and aborts, even with status set to off, if I include it as a layer.
> When I test the URL for the landsat map from lynx I get an XML file
> with a missing bbox argument error. The url being used for this
> connection is identical to that found in the online tutorial viewable
> map file. The online tutorial works perfectly.
> All other utilities, binaries, cgi capabilities, etc tested work
> exactly as documented.
> Any thoughts?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
