[Mapserver-users] mapserv cgi andraster layers again
Pericles S. Nacionales
nacional at cbs.umn.edu
Fri Apr 16 15:29:27 EDT 2004
Andrew,
Have a look at your Apache error_log. Chances are some of your
libraries are not being seen by MapServer. If this is the case and
assuming you have installed the libraries you compiled in "/usr/local/",
run the command "/sbin/ldconfig" as root to create/refresh the links to
your libraries. You can then run "/sbin/ldconfig -p | more" to check
that the libraries needed by MapServer are "registered". If they're
not, edit /etc/ld.so.conf as root and add "/usr/local/lib" (or wherever
you installed your libraries). You can then rerun "/sbin/ldconfig" and
your problems should go away.
One caveat: There may be reasons not to add "/usr/local/lib" to your
ld.so.conf file. You might have duplicate libraries that could screw
other things.
Good luck!
-Perry N.
On Fri, 2004-04-16 at 13:32, Andrew wrote:
> I have converted all my tiff files to png, renamed all the .tfw world
> files with a .wld extension, and I can get png files to display (albeit
> not to the necessary scale or projection necessarily). My mapserv "says"
> it supports tiff input, and the gdal conversions from tiff to png and
> back work fine. I still get the "premature end of script headers" when I
> use tiffs. The wms connection still fails, but the same tiff file saved
> locally and used in place still causes the cgi to abort.
> Is there a simple algorithm or technique to use to georeference the png
> files made from the tiff files so I can use the world files directly?
> What is the best workaround, if the tiff support remains broken? Is
> there a known "fix"?
> Thanks
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
