[Mapserver-users] mapserv cgi andraster layers again....solved FINALLY
Daniel Morissette dmorissette at dmsolutions.ca
Sun Apr 18 07:22:48 PDT 2004
Andrew wrote:
> The problem, in case anyone else is as thick as I am, was that I had
> tiff AND gdal enabled in the configure. This was the dependency conflict
> I guess. I suggest the documentation be amended to make it clear that
> the "RECOMENDED" libtiff and perhaps libgeotiff should NOT be included
> if gdal is being incorporated. The revised " mapserv -v" output will
> then no longer include the "INPUT=TIFF", and all will be well.
Which doc are you referring to?
I have created bug 630 about this:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=630
Thanks
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
More information about the MapServer-users mailing list
