[Mapserver-users] One more question -
Anna Blanchard
blanchal at westminster.edu
Sun Apr 18 15:22:51 EDT 2004
One more question -
how do a specify in that block what projection I'm using? do i
just write out the complete projection name?
thanks for the help -
Anna
>Anna,
>You need to do two things.
>1) in the main MAP definition of the map file you need to specify what
>projection you want your map image to be displayed in with a
PROJECTION
>... END block.
>2) in each data LAYER you need to specify what PROJECT the data is in
>using a PROJECTION ... END block for that layer.
>Mapserver will take care of the rest for you.
>-Steve W.
>Anna Blanchard wrote:
> Hi -
> I'm new at this and have a couple of possibly easy questions -
> I'm having trouble seeing my data in my mapserver because of the
> projection - With one set of data that uses a State Plane projection
> system I see everything fine - however two of my layers use a
different
> projection (Lambert Conformal Conic) - how do i get these layers to
> display? I've seen the porjection function in others code however i
> don't know what the definitions of those variables -
> the variables are that I can't define are:
> PROJECTION
> "proj=utm"
> "ellps=GRS80"
> "zone=12"
> "north"
> "no_defs"
> END
> any suggestions would be great! thanks -
