[Mapserver-users] Itemquery - getting started, having problems
Richard Greenwood
rich at greenwoodmap.com
Sun Apr 18 22:06:17 EDT 2004
Mike Reilly wrote:
> Bottom posting - see response at bottom.
>> From: Richard Greenwood <rich at greenwoodmap.com>
>> To: Mike Reilly <mikereilly_7 at hotmail.com>
>> CC: mapserver-users at lists.gis.umn.edu
>> Subject: Re: [Mapserver-users] Itemquery - getting started, having
>> problems
>> Date: Sun, 18 Apr 2004 16:53:43 -0600
>> Mike Reilly wrote:
>>> Hi:
>>> I'm just starting to try to work with itemquery and itemnquery. I've
>>> read the cgi reference, the mapfile reference, trolled through the
>>> archives and spent a number of hours trying to get this started. I'm
>>> obvoiusly missing something significant, however. Here's what I'm
>>> working with:
>>> A number of shapefiles to create maps from - I have all other
>>> functions working on my application - can zoom, pan, query the map,
>>> etc. What I want to do now is be able to link to the map from other
>>> pages in order to display a single site - either point or polygon
>>> from one of two shapfiles - tuspoints and mergeplys. Both of these
>>> shapefiles have a field (attribute?) named SITEID. I want to be able
>>> to display these point or poly sites on my map based on whether they
>>> match a specific SITEID value. After looking through the docs and
>>> archives, I figured that forming a URL with mode=itemquery was what I
>>> wanted (am I going in the right direction here?). After looking at
>>> one of Richard Greenwood's sites, I figured this was probably teh
>>> correct way to go.
>>> I have not made any modifications to the shapefile I'm using in order
>>> to use mode=itemnquery (am I missing something here?). Here's an
>>> example of a URL I tried to create in order to get my map displayed
>>> correctly:
>>> http://192.168.0.3/cgi-bin/mapserv.exe?map=f:/program%20files/apache%20group/apache2/htdocs/Kitasoo/tus2-1.map&mode=itemquery&qitem=SITEID&qstring=1010&layer=landpl+streamln+lakespl+conmajl&qlayer=tuspoints
>>> This gives me the following output:
>>> msQueryByAttributes(): Search returned no results. No matching
>>> record(s) found.
>>> In the tuspoints layer, there is a site with a SITEID that has the
>>> value 1010. Not sure why I'm getting no matching records found. Can
>>> anyone point me in the right direction here?
>> Two things to try:
>> 1. Be sure that the object having SITEID = 1010 is within the extents
>> that you have defined in your map file.
>> 2. Add 'mapext=shapes' to your query string.
>> Richard Greenwood
>> www.greenwoodmap.com
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> I have added mapext=shapes to the URL, and the extents as defined in my
> mapfile include the entire data set in all shape files. I've also tried
> using other SITEID numbers. Here is a snippet from my map file defining
> some of the basics as well as including two shapefiles in the layer
> (skipping inclusion of the other 20+ layers):
> NAME EX2.1_
> IMAGETYPE png
> EXTENT 768897.25886 810841.50306 876598.91242 913853.62854 # LAEA
> #EXTENT -97.5 41.619778 -82.122902 49.38562 # Geographic
> SIZE 792 592
> SHAPEPATH "f:/program files/apache group/apache2/htdocs/Kitasoo/tus"
> SYMBOLSET "f:/program files/apache
> group/apache2/htdocs/Kitasoo/symbols/symbols35.sym"
> FONTSET "f:/fonts/fonts.list"
> IMAGECOLOR 207 245 255
> WEB
> TEMPLATE 'f:/program files/apache
> group/apache2/htdocs/Kitasoo/tus2-1.html'
> IMAGEPATH 'f:/program files/apache group/apache2/htdocs/tmp/'
> IMAGEURL 'http://192.168.0.3/tmp/'
> END
> LAYER # TUS polygon layer begins here
> NAME tuspoints
> DATA "mergeplys"
> STATUS ON
> TYPE POLYGON
> TOLERANCE 3
> PROJECTION
> # "init=epsg:4326"
> END
> CLASSITEM "LOCATION"
> CLASS
> EXPRESSION "land"
> COLOR 160 160 255
> TEMPLATE "templates/land_query.html"
> OUTLINECOLOR 0 200 0
> END
> CLASS
> EXPRESSION "Ocean"
> COLOR 100 255 100
> OUTLINECOLOR 0 255 0
> END
> END
> # ***** display all point layers begin here.
> LAYER
> NAME "tuspoints"
> DATA "tus points"
> STATUS ON
> TYPE POINT
> MAXSCALE 5000000000
> TOLERANCE 3
> CLASS
> SYMBOL 7
> SIZE 6
> TEMPLATE "templates/pointdata_query.html"
> COLOR 255 0 0
> END
> END
Looks like you need a FILTERITEM and a FILTER in your map file. For example:
FILTERITEM SITEID
FILTER "%SITEID%"
Also be sure you have a querymap object defined in your map file. For
example:
QUERYMAP
STATUS ON
STYLE SELECTED
END
(But this would not cause the error you are reporting.)
Richard Greenwood
